Installed this morning and seems to run without a glitch!
  • Thanks 2
installed and now Fibaro for tablet stops working. Please fix this
There are errors, the scenes won't start after a few hours, I restored the previous versions.
I have quite an extensive system. After starting, everything is fine, it works flawlessly, but after a few minutes - the scenes stop working, e.g.: turn on the light after detecting motion.
Edited by greg77
Did you maybe download the logs before rolling back?
We did not notice anything similar on our tests systems.
Installed yesterday and seems to run fine.
Installed on a Z-Box Hub, and the update appears to have borked my Zapato keypad. Perhaps related to the Z-Wave engine update? Tried uninstall and reinstall, and no luck. It refused to sync with the hub. Maybe it it time to abandon it, but I had it working so good finally on the earlier rev. of HC3. If the device is incompatible with the new Z-wave engine, just let me know, OK? If I really want it back, I can recover the down rev. backup.
Thanks.
