Problem with backup restore - Home Center 3
Hello everyone
For several weeks now, older scenes have consistently not been executed automatically. However, the process was interrupted several times when uploading the backup. Since then, I can no longer access the system - neither via the IP address nor via the Fibaro Finder Tool.
I have tried to restore the backup via recovery mode, but the restore fails there too.
Details:
  • Home Center 3
  • Firmware version before error 5.180.17
Current status:
  • No access via web interface
  • Backup upload fails
  • Recovery mode is accessible, but backup cannot be loaded there either
Error message:
  • Error while writing Z-Wave dump file
I would be very grateful for your help.
Many thanks in advance
Jonas
You probably shoult contact support. Only one post about this problem:
  • 3 weeks later...
Mam to samo, po aktualizacji do  5.180.17 centrala ciągle sie zawiesza i jest utrudniony dostęp do nie i nie można wrócić do kopi zapasowej. procesory wariują
