Philio PSK01-B keypad on HC3
I have a Philio PSK01-B keypad (ID 920)  on HC3. I want a Lua trigger scene to run when the keypad unlocks the lock with a user code (eg 1234). Is there a way to reliably detect the user code in HC3 Lua? I have programmed this code in the keypad.
11 answers to this question
On 6/18/2026 at 11:07 AM, Vallheru said:
Hello, do you have any idea, how to solve this problem without swiching back to zw2? I am able to arm house, but disarm without accessControlEvent doesnt work.
It seems this keypad is cursed. In entry control mode is not possible call buttons, In access control mode is no longer possiible to call the scenarios.
for now all you can do is:
- send Fibaro coffee cup @m.roszak
- switch back to ZW2
- change temporairy the way you using it, e.g. use the code still to unlock the panel, and then once unlocked two scenes to do something based on "user clicked on lock" and "user clicked on unlock".
Lock key is 11, unlock is 12, e.g.
Good afternoon,
I use this as the condition in a scene for the Philio PSK01:
As you can see I have 4 users setup in the keepad:
Jim
    Dear Jimicr,
    Apologies for my late reply; I saw your message today. After resetting and re-adding it a few times, I was able to get it working using your LUA code. The trigger works exactly as I had hoped.
    Many thanks for your help.
    here is a video on how to use and setup the PSK01 for anyone else who needs it
    @morpheus75 i assume you don't have zw3 engine installed, right?
    @m.roszak i took the chance and tested a bit:
    With zw3 engine and S2AC (tested with fw 5.180.17 and 5.201.18) i can't get it running, device seems to send notifications, they coming in and are visible in history, however scene didn't trigger on any accessControlEvent
    if i change the params back to scene mode (or unlock in access mode first and click one of the scene buttons), then of course the centralSceneEvent trigger is working, but of course accessControlEvent make more sense for access decice.
    Tested on 5.202.x9 on lab hc3l, with zw3 and S2AC, accessControlEvent is still not working. Reversed back the hc3l to zw2, added PSK01 device with S0 and it works - so at least this is OK but of course not what i need, so upgraded to zw3 (with migration wizard). Unfortunately after migration, the accessControlEvent stopped to work again.
    As last test removed the PSK01, set it to default and included again on zw3, this time with S0 forced. Result is however the same, accessControlEvent is being visible in history as event, but scene is no triggering on it
    So definitely something wrong with zw3 and accessControlEvent.
    no idont have zwave 3 engine,
    still running my system on zwave 2
    sorry mate, i havent upgraded to zwave 3 engine just yet. looking @tinman post earlier looks like it doesnt work at the moment
    Hello again and thx tinman,
    I have done some testing and found the following:
    • accessControlEvent does NOT work as a scene trigger on ZW3 (as you mentioned)
    • centralSceneEvent works fine for both buttons (11 and 12) when parameter 1 = 2 (central scene mode)
    • So for now I can using centralSceneEvent for both ARM (button 11) and DISARM (button 12) without PIN code
    The only thing I am missing is the PIN security for DISARM, which was possible with accessControlEvent on ZW2.
    Do you know if Is there any plan to fix accessControlEvent as a scene trigger on ZW3? Or is there any other workaround to use PIN + button for DISARM on ZW3?
    Thanks!
    as i said, it works in access control mode, as you can see i do have users with PIN, and my keypad is set to access control
    The user has to wake up keypad, enter PIN, confirm it with unlock key, the keypad will then lit up blue which means it is unlocked and it does react to central scene events
    You see in my logs, unlocked and then central scene on key 11 to ARM, or unlock and then central scene on key 12 to DISARM
    OMG that's crazy. How can I explain this to my family members? 😊
    I can bypass keypad wake up by this command, am I right?
    -- Disable LED sleep mode - we are away
    fibaro.call(keypad_ID, "setConfiguration", 4, 1, 0)
    fibaro.debug("SceneARM", "Sleep mode disabled - LED stays on")
    So unlock will have two phases only.
    Once more thank you.
