Philio PSK01-B keypad on HC3
I have a Philio PSK01-B keypad (ID 920)  on HC3. I want a Lua trigger scene to run when the keypad unlocks the lock with a user code (eg 1234). Is there a way to reliably detect the user code in HC3 Lua? I have programmed this code in the keypad.
7 answers to this question
Good afternoon,
I use this as the condition in a scene for the Philio PSK01:
As you can see I have 4 users setup in the keepad:
Jim
    Dear Jimicr,
    Apologies for my late reply; I saw your message today. After resetting and re-adding it a few times, I was able to get it working using your LUA code. The trigger works exactly as I had hoped.
    Many thanks for your help.
    here is a video on how to use and setup the PSK01 for anyone else who needs it
    @morpheus75 i assume you don't have zw3 engine installed, right?
    @m.roszak i took the chance and tested a bit:
    With zw3 engine and S2AC (tested with fw 5.180.17 and 5.201.18) i can't get it running, device seems to send notifications, they coming in and are visible in history, however scene didn't trigger on any accessControlEvent
    if i change the params back to scene mode (or unlock in access mode first and click one of the scene buttons), then of course the centralSceneEvent trigger is working, but of course accessControlEvent make more sense for access decice.
    Tested on 5.202.x9 on lab hc3l, with zw3 and S2AC, accessControlEvent is still not working. Reversed back the hc3l to zw2, added PSK01 device with S0 and it works - so at least this is OK but of course not what i need, so upgraded to zw3 (with migration wizard). Unfortunately after migration, the accessControlEvent stopped to work again.
    As last test removed the PSK01, set it to default and included again on zw3, this time with S0 forced. Result is however the same, accessControlEvent is being visible in history as event, but scene is no triggering on it
    So definitely something wrong with zw3 and accessControlEvent.
    no idont have zwave 3 engine,
    still running my system on zwave 2
    Hello, do you have any idea, how to solve this problem without swiching back to zw2? I am able to arm house, but disarm without accessControlEvent doesnt work.
    It seems this keypad is cursed. In entry control mode is not possible call buttons, In access control mode is no longer possiible to call the scenarios.
    sorry mate, i havent upgraded to zwave 3 engine just yet. looking @tinman post earlier looks like it doesnt work at the moment
