Martin... 0
Its already the second Dimmer 2 with the same issue:
I have 4 dimmable LED spots. After installing the Dimmer 2 and running auto calibration everything is working fine. However, after some weeks the dimmer does not correctly dims the lights and shows a "Load Error". After that I cant dim anymore, the lights are either full on or at very low level around 10% I presume. Running auto calibration does not fix the problem, factory reset of the device didn't help either. The dimmer seems defect. I experienced this issue no the second time on the same lights. Can be the LED-Dimmer and Dimmer2 configuration cause a broken Dimmer2 after a while? What can I do?
