Neo Andersson 232
@m.roszak
Dear Michael and other developers
May a kindly ask you to finally give me a confirmed manual what and how to use.
I am really tired of hunting bugs, or finding workarounds..
Can you please tell me what will work, what will never work, what is just a temporary bug, or what is the right syntax etc regarding dropdowns , what will work only in new UI etc
I have just started to test the dropdowns after the new update, to check if things work or not.
Populate dropdown, select one, select all, deselect one, deselect all, delete one, delete all, etc so the basics that is needed for functonality
The first (the populate part) worked, so i was able to populate the dropdown.
The second failed right away. User has to click away an back to get the refrshed view. So i stopped testing the rest, and rather ask for your confirmation, what will work, and what not etc, as i asked above
So check the video and please give me some update, will these few UI elements that we have to cook from ever work as expected?
Can you please give us the final working LUA syntax for single and multidropdowns for these cases:
1. Populate
2. Select one specific / Select multiple specific / Select all
3. Unselect one / Unselect multiple / Unselect all
4. Delete one / Delete multiple / Delete all
Also specify please what works only in New UI what not etc.
Will help a lot, at least i know, what to offer in the future to customers, and what to avoid.
