Anyone who has installed this release and can share some experience?
Got it, everything's fine, all devices are working!
Prior to this update and migration, everything worked flawlessly. However, after the process completed, one of my blind modules stopped behaving correctly. Specifically, it is no longer able to tilt the slats (the blind moves up and down, but slat orientation does not respond).
Here are the exact technical details of the affected device taken from the configuration panel:
Type: Žalúziový modul (Roller Shutter / Blind Control Module)
Role: Benátske žalúzie (Venetian Blinds)
Device Version: 8.2
Node.Endpoint: 74.0
The device is properly configured with the correct role, but the positioning of the slats is completely unresponsive.
Device Version: 8.2
Node.Endpoint: 74.0
Maybe after the update you can try recalibrate them...
Device Version: 8.2
Node.Endpoint: 74.0
Those stopped responding after migration? Slats I mean?
@Support FIBARO take a look at that.
We weren't able to reproduce the issue, but we'll have it in mind.
