  1. Today
  2. I'm afraid this is not functioning... self.logLevel = DEBUG does not cut TRACE messages. However DEBUG has non-nil value (3).
  3. So, there is no local API avaialble so it can be done by QuickApp <-> tado Cloud Api. The problem is that for free users its limited to 100 requests/day so it may not be enough to actually use the device on daily basis. With subscription limit is 20k requests - its costs ~30 euro/year. Accodring to my knowledge there is no QuickApp made yet for this, so you will need to do it yourself or find someone who can do it for you.
  4. Yesterday
  5. Hi @Dunkigrease, Finder app is replaced with browser link: http://find.yubii.cloud, but only for new gateways. Since HC2 and HCL have reached EOL, I do not think they have any plans to make new finder app.
  6. I received notification that very soon Apple win longer support Intel silicon based apps on Apple MAC hardware using Apples silicon. This applies to the Finder App version 26.4 which I am currently running. Does anyone know if Fibaro has a plan to issues a new version of Finder to address this problem? Thanks
  7. QA Dist Manager is the preferred way to upgrade/update Yahue https://forum.fibaro.com/topic/80052-qa-dist-manager/ ------- bug in v0.2.69 when watchdog poll was selected. Fixed in v0.2.70
  8. I was recommended to clean them with isopropylalcohol.
  9. Last week
  10. is there a quickapp for tado wired smart thermostat v3+? Is there a quick app for the tado wired smart thermostat v3+? Please help, I'm new. I apologize in advance if I broke any rules.
  11. Hi jgab, thanks for the great work on YaHue v2! I wanted to update to the latest version, but I couldn't find the update QuickApp variable in my installation. I created it manually (name: update, value: yes) and saved it, but unfortunately nothing happened afterwards — no update was triggered. Thanks any suggestions-
  12. I pushed v0.2.69. It has 2 main fixes. - buttons and sensors don't republish their events when the QA starts up (thanks @_Marian_) - a new logic to keep the event stream open. Sometimes the event stream opened to the Hue hub goes stale and it's hard/impossible to find out from the net.HTTPClient code. Now there is a quickAppVariable 'watchdog' that can be set to 'time' or 'poll' - 'time', means that we monitor the socket and if we don't get any event for x seconds we restart the QA and reconnects. - 'poll', means that if we haven't got any events for x seconds we poke the hub so it emits an event, if no event back we restart the QA: The time x is set by the quickAppVariable 'watchtime'. The default for 'watchdog' is 'time' The default for 'watchtime' is 1800 (30min) for time, and 60 for poll (1 min) The default is 'time' now to mimic the old behavior, but I would recommend people to try out poll as it is more effective and responsive if the stream goes stale.
  13. Thanks, I do believe I know what the problem is. Will have a look at it...
  14. Hi, I'm running a Hue Dimmer Switch through Yahue v2 on HC3, and I'm seeing a reproducible issue: roughly every 30 minutes, during what looks like a periodic reconnect/resync cycle, button 4 fires a full Pressed → Released sequence even though nobody touched the switch. Buttons 1–3 do not show this behavior — they're correctly reset to idle. Example from my log (this pattern repeats every ~30 minutes, all day): [08:11:37] status connected [08:11:37] button:1 _ _ [08:11:37] button:2 _ _ [08:11:37] button:3 _ _ [08:11:37] battery 100 [08:11:37] status connected [08:11:37] battery 100 [08:11:37] button:4 _ _ [08:11:38] button:4 Pressed initial_press [08:11:38] button:4 Released Note that buttons 1, 2, and 3 all reset cleanly to _ _ during the resync, but button 4 gets an extra Pressed initial_press / Released pair about 1 second after its own _ _ reset. This exactly matches the last button I physically pressed on the dimmer (button 4, hours earlier) — so it looks like the resync logic is somehow re-emitting the last "active" button state as a fresh press instead of just resetting it to idle like the others. This causes real problems downstream: I have an HC3 scene bound to button 4 (hub.scene("execute", ...)) that gets triggered every 30 minutes by this phantom event, forcing my target scene to run repeatedly without any real button press. Is this a known issue? Happy to provide more logs or test a fix if useful. Thanks!
  15. The gateway has no effect on the device's alarm activation - this is a problem with the device itself. It is possible that one of the sensor components is contaminated/dirty or damaged.
  16. Ah okay, thanks. I tried writing something based on what m.roszak proposed: I removed the device selection from the QA and hardcoded the devices instead, added a "Home_Presence" variable and a trigger counter block (useful for multiple manual activations—it caps at 2; does that make sense? Who knows!), and finally implemented dynamic icon switching. Everything works except the geofencing.☹️ The code comments are in Italian—please bear with me. They’re more for my own benefit than for yours, since you all know a lot more about this than I do.🤭 Geofence_iPhone_1147.fqa
  17. Hi @GasDeKu, I'm referring to my own quick app. It will be available for download after I preform thorough testing.
  18. The problem was identified and reported to the technical department.
  19. Further discussion of the issue has been moved to a private channel. After identifying the cause or resolving the issue, the appropriate information will be published.
  20. Thanks for the support. Which quick app are you referring to? I tried geofence_event.fqa and v2 but to no avail.
  21. I have the same problems sometimes too. WHat I miss is haveing a notification in HC3 why this did occur? In my opinion it should be no problem if the code inside of the smoke sensor desiced to enable alarm having a message sent to the controller also including thew reaons for this alarm... But normally I do see nothing in the HC3 (no message, grpahs are looking fine and so on).
  22. @Support FIBARO, take a look at this please. It should report the hcName defined in the settigs of the hub, for some reason its being swapped with serial number as you report. I confirm on my system that it "reverts" to the serial number by itself - don't know the reason
  23. Hi @m.roszak, I use location panel to get location settings for my HC3 and I notice inconsistency in reporting HC3 name. Most of the time reported name is actually serial number of the HC3. After I changed name of my HC3, for some time this new given name was reported, but then after some time again serial number. Since in the returned json: [ { "id": 219, "name": "HC3-xxxxxxxxx", "latitude": 00.386733293331616, "longitude": 00.471836863604455, "radius": 150, "address": "Xxxxxxxx, Croatia", "created": 1783151231, "modified": 1783151231, "home": true } ] there is a "name" and not "serialNo", shouldn't actually contain user given name? Also, since users can add another location, what those other locations can be used for? I guess, I can add location of my work and then get triggers when I arrive at work?
  24. can do it with the swagger api I think:
  25. Hi. How does the neighbor option look on a Z-Wave 3 engine? In the old version, you could refresh the neighbor list, but in Z-Wave 3 there's no such option... How does it work now if you want to move a device to another place? Will the device handle it on its own? Does it check neighbors on its own from time to time? Or do you have to manually add it again?
  26. @m.roszak, Because there is no z-wave device with those options. Can you add this device FP300 Zigbee. It's a real game changer it has pir and mmWave. Tip if possible also the enter and leave option, what is missing in the FP1 Thanks in advance
  27. That is going to be due to Fibaro's implementation of the Zigbee protocol. Not much you can do natively in HC3 - Zigbee devices either work or they don't. There are no editable parameters etc
  28. I‘ve included the Aquara FP300 zigbee occupancy sensor, but it only shows temperature, illuminance, but no occupancy - any ideas? Thanks!
