bonjour a tous! je suis a la recherche de l information suivante: peut t on integrer une camera TAPO C 200 C ? merci pour la reponse apportee -
I'm afraid this is not functioning... self.logLevel = DEBUG does not cut TRACE messages. However DEBUG has non-nil value (3).
lvae joined the community
So, there is no local API avaialble so it can be done by QuickApp <-> tado Cloud Api. The problem is that for free users its limited to 100 requests/day so it may not be enough to actually use the device on daily basis. With subscription limit is 20k requests - its costs ~30 euro/year. Accodring to my knowledge there is no QuickApp made yet for this, so you will need to do it yourself or find someone who can do it for you.
karel de munck joined the community
zeynel joined the community
Jozsef joined the community
Brunhylde joined the community
uncoated929 joined the community
Hi @Dunkigrease, Finder app is replaced with browser link: http://find.yubii.cloud, but only for new gateways. Since HC2 and HCL have reached EOL, I do not think they have any plans to make new finder app.
QA Dist Manager is the preferred way to upgrade/update Yahue https://forum.fibaro.com/topic/80052-qa-dist-manager/ ------- bug in v0.2.69 when watchdog poll was selected. Fixed in v0.2.70- 276 replies
I was recommended to clean them with isopropylalcohol. -
Automated joined the community
Hi jgab, thanks for the great work on YaHue v2! I wanted to update to the latest version, but I couldn't find the update QuickApp variable in my installation. I created it manually (name: update, value: yes) and saved it, but unfortunately nothing happened afterwards — no update was triggered. Thanks any suggestions-- 276 replies
I pushed v0.2.69. It has 2 main fixes. - buttons and sensors don't republish their events when the QA starts up (thanks @_Marian_) - a new logic to keep the event stream open. Sometimes the event stream opened to the Hue hub goes stale and it's hard/impossible to find out from the net.HTTPClient code. Now there is a quickAppVariable 'watchdog' that can be set to 'time' or 'poll' - 'time', means that we monitor the socket and if we don't get any event for x seconds we restart the QA and reconnects. - 'poll', means that if we haven't got any events for x seconds we poke the hub so it emits an event, if no event back we restart the QA: The time x is set by the quickAppVariable 'watchtime'. The default for 'watchdog' is 'time' The default for 'watchtime' is 1800 (30min) for time, and 60 for poll (1 min) The default is 'time' now to mimic the old behavior, but I would recommend people to try out poll as it is more effective and responsive if the stream goes stale.- 276 replies
- 2
Thanks, I do believe I know what the problem is. Will have a look at it...- 276 replies
Hi, I'm running a Hue Dimmer Switch through Yahue v2 on HC3, and I'm seeing a reproducible issue: roughly every 30 minutes, during what looks like a periodic reconnect/resync cycle, button 4 fires a full Pressed → Released sequence even though nobody touched the switch. Buttons 1–3 do not show this behavior — they're correctly reset to idle. Example from my log (this pattern repeats every ~30 minutes, all day): [08:11:37] status connected [08:11:37] button:1 _ _ [08:11:37] button:2 _ _ [08:11:37] button:3 _ _ [08:11:37] battery 100 [08:11:37] status connected [08:11:37] battery 100 [08:11:37] button:4 _ _ [08:11:38] button:4 Pressed initial_press [08:11:38] button:4 Released Note that buttons 1, 2, and 3 all reset cleanly to _ _ during the resync, but button 4 gets an extra Pressed initial_press / Released pair about 1 second after its own _ _ reset. This exactly matches the last button I physically pressed on the dimmer (button 4, hours earlier) — so it looks like the resync logic is somehow re-emitting the last "active" button state as a fresh press instead of just resetting it to idle like the others. This causes real problems downstream: I have an HC3 scene bound to button 4 (hub.scene("execute", ...)) that gets triggered every 30 minutes by this phantom event, forcing my target scene to run repeatedly without any real button press. Is this a known issue? Happy to provide more logs or test a fix if useful. Thanks!- 276 replies
_Marian_ joined the community
The gateway has no effect on the device's alarm activation - this is a problem with the device itself. It is possible that one of the sensor components is contaminated/dirty or damaged. -
bartosdu joined the community
