- 394 replies
LOGIP joined the community
Let me answer at some length, because it may indeed seem strange that I have been showing off various ideas, but somehow never include the code. The programs I write, and in general the area of programming that interests me, are not particularly popular in our community. For example, I am not interested at all in creating integrations with various devices, which are desired by the community, and rightly so. What I do interests, I think, only a handful of people, who nevertheless provide me with a certain amount of support and satisfaction through their likes. Before I sit down to program, I spend many hours constructing the contract, deciding how it is all supposed to work. I am not a professional programmer, only an amateur, but this is what the DNSfD project taught me: a concept that is wrong in one small but crucial place means either throwing the code away or going through the torments of Tantalus while trying to “repair” it. You should also know that this is not a simple program, such as a controller for blinds or a fireplace. It is around 3,000 lines of code. It would have to be tested thoroughly, because bugs and failures in a server-based model can be mysterious and difficult to track down. I didn't do this to the end, yet. Creating client-server software requires a particular kind of experience. It is an area which, it seems to me, really follows its own rules. Something always appears that you had not anticipated, even after spending a long time thinking about how everything should work. TableMan happens to be a relatively simple project, although it has quite an extensive “construction language.” But even there I have already added things I had not expected. Another project, DNSfD, showed very clearly how difficult it is to explain to the community a concept that is systemic, tool-oriented. It also showed that more sophisticated, automated and elegant solutions do not necessarily win. Not because they are bad, but because first you still have to explain why they exist at all and how they are supposed to be used. Documentation would also have to be written. AI would probably help with that, but it would not do everything. I simply cannot find the time for it anymore. It would probably be a solid 20 to 30 pages in two languages. On the other hand, the era of sweet idleness in my life came to an end, suddenly and unexpectedly, and I had to turn programming into an additional source of income. In short, in my situation these would have to be paid solutions, so that I could be fully available to users. That, in turn, creates other problems which I am not actually in a position to deal with. I will think some more about this particular project, but for now I have to admit that, as a general rule, I had no intention of publishing these programs. I only intended to publish information about them, which may also be valuable in some way. I apologize for this somewhat chaotic and, as usual, long reply, but I am simply writing what I think.
Message to @m.roszak. SVG graphics in QuickApp interface makes it possible to create UI that are more visually attractive than those built only with the standard UI elements or simple HTML. At the moment, however, SVG is displayed only as an image, so individual parts of the graphic cannot respond to clicks. This is really unfortunate. Even very limited click support would make it possible to create room plans, control panels or installation diagrams even much attractive - because of reaction on a click over the element... I am not suggesting that arbitrary JavaScript should be allowed inside SVG files. That could obviously create security concerns. However, the controller already supports calling device actions through the existing callAction endpoint, including over HTTPS, like this: https://user:password@ip_address/api/callAction?deviceID=ID&name=nazwa_funkcji Perhaps SVG could therefore be given one simple and controlled mechanism that would call such an action when clicked, using the user’s current authenticated session. For example, it could look like this: <a href="fibaro-action:call?deviceID=1611&name=turnOn"> ... </a> Such a link would not open a website. Instead, the HC3 interface would intercept it and execute the normal device action call over HTTPS. This way, the SVG would not need to contain a username, password, or any JavaScript code. Scripts, external links, and other potentially unsafe elements could remain blocked. Another possible approach could be a dedicated attribute - as an information to the interface what action should be executed. Of course, I do not know how the current interface is implemented or how much work such a change would require. From the user’s point of view, however, even this simple ability to call an existing device function would be enough. Would it be possible to consider adding this kind of limited click support for SVG? If anyone agrees with this suggestion, please add your support. Perhaps it will help strengthen our voice.
- 4
piet eeken joined the community
Thank you @trob.
- 394 replies
The problem may have been there all the time... try v0.2.75 with a fix.- 283 replies
- 394 replies
