It's a "simple" QA that relies on the QuickAppChildren to realise the Hue devices.
This means that the user interfaces are limited to what are supported by the child app classes.
Supported Hue device classes:
ZLLSwitch.
Hue switch with 4 buttons. Creates centralSceneEvents similar to a Fibaro keyFob (com.fibaro.remoteController)
The interpretation is
     keyId = hueKeyValue // 1000
     keyAttribute = ({"Pressed","HeldDown","Released","Released"})[hueKeyValue % 1000 +1]
It also supports setValue('value',value) to simulate a key press.
ZLLTemperature.
Hue temperature sensor. Behaves like a standard fibaro.com.temperatureSensor.
ZLLLightLevel.
Hue light sensor. Behaves like a standard fibaro.com.lightSensor.
The device quickAppVariables  'daylight' and 'dark' is updated with resp. Hue attribute.
ZLLPresence
Hue presence sensor. Behaves like a standard fibaro.com.motionSensor.
Extended color light
Hue RGB light. Behaves like a fibaro.com.philipsHueLight.
supports:
fibaro.call(<id>,"turnOn")
fibaro.call(<id>,"turnOff")
fibaro.call(<id>,"toggle")
fibaro.call(<id>,"setValue",value)                   -- dim value 0..100
   If the value is a table the value is sent directly to the Hue light as a Hue property table.
  Ex. fibaro.call(<id>,"setValue",{effect='colorloop',bri=50})
        fibaro.call(<id>,"setValue",{startup={customsettings={xy={0.73500005089041,0.26499994910959}}}})
fibaro.call(<id>,"setColor",red, green,blue).  -- color 0..255
fibaro.call(<id>,"changeBrightness")             -- brightness 0..255
fibaro.call(<id>,"changeHue")                        -- 0..65535
fibaro.call(<id>,"changeSaturation")              -- 0..255
fibaro.call(<id>,"startLevelIncrease")
fibaro.call(<id>,"startLevelDecrease")
fibaro.call(<id>,"stopLevelChange")
fibaro.call(<id>,"toggleDim",<boolean>) -- Toggle dim direction. true with 'stop'
The device quickAppVariable  'state' is updated with the Hue state
Dimmable light
Hue dimmable white light. Behaves like a fibaro.com.multilevelSwitch.
supports:
fibaro.call(<id>,"setValue",value)                   --- dim value 0..100
Color temperature light
Mapped as a Dimmable light
Color light
Hue color light. Behaves like a fibaro.com.colorController.
supports:
Room
Hue light group.
   If the value is a table the value is sent directly to the Hue group as a Hue property table.
fibaro.call(<id>,"setScene",<Hue scene ID or scene name>)
Hue CLIPS devices
CLIPPresence          => com.fibaro.motionSensor          class='ZLLPresence'
CLIPTemperature.   => com.fibaro.temperatureSensor class='ZLLTemperature'
CLIPPressure           => com.fibaro.binarySwitch           class='BinarySwitch'
CLIPHumidity           => com.fibaro.humiditySensor.      class='Humidity'
CLIPOpenClose.      => com.fibaro.binarySensor.          class='BinarySensor'
The startLevelIncrease, startLevelDecrease, and stopLevelChange makes it possible to bind a remote controller that support centralSceneEvent to dim when a button is held down and stop dimming when the button is released.
The lights store their Hue values in a quickAppVariable 'state'.
This can be retrieved like below and ex. used to set default startup values for Hue lights...
local function getVar(id,name)
  local vars = api.get("/devices/"..id).properties.quickAppVariables or {}
  for _,v in ipairs(vars) do
    if v.name==name then return v.value end
function QuickApp:main()
   state = getVar(1435,"state")                              -- retrieve current color
   fibaro.call(1435,{startup={customsettings={xy=state.xy}}) -- set as default startup
  • Thanks 2
Other Files from jgab
AntoineF
Hi @jgab,
I am looking at your QA with a lot of interest and try to get an understanding if it is possible to command the Color Temperature of a White Ambiance bulb? Form what I see, we can control brightness (fibaro.call(ID, "changeBrightness", value) but cannot find any command to control the Color Temperature. Do you know it this is possible to do?
Thanks a lot for the help
jgab
21 hours ago, AntoineF said:
Hi @jgab,
Yes, you can set the temperature directly with
  local cal = math.floor((1000000 / 2700))
  fibaro.call(LampID,"setValue",{ct=cal})
I may add a "setTemperature" in the next release so you don't need to do the arithmetic...
AntoineF
@jgab, thank you for the hint. I am trying to add this to a Lua scene but cannot make it work. Sorry for the burden, it's the first time I am looking into such thing. For a basic test, I just created a scene and run it without any condition to see if it works. My lamp ID created from your quick app is 34 so I am using:
fibaro.call(34,"setValue",{ct=cal}
What is/are the other value to change? I tried a bunch of things to replace the ct or ct=cal etc....?
Thanks a lot
