It's a "simple" QA that relies on the QuickAppChildren to realise the Hue devices.
This means that the user interfaces are limited to what are supported by the child app classes.
Supported Hue device classes:
ZLLSwitch.
Hue switch with 4 buttons. Creates centralSceneEvents similar to a Fibaro keyFob (com.fibaro.remoteController)
The interpretation is
keyId = hueKeyValue // 1000
keyAttribute = ({"Pressed","HeldDown","Released","Released"})[hueKeyValue % 1000 +1]
It also supports setValue('value',value) to simulate a key press.
ZLLTemperature.
Hue temperature sensor. Behaves like a standard fibaro.com.temperatureSensor.
ZLLLightLevel.
Hue light sensor. Behaves like a standard fibaro.com.lightSensor.
The device quickAppVariables 'daylight' and 'dark' is updated with resp. Hue attribute.
ZLLPresence
Hue presence sensor. Behaves like a standard fibaro.com.motionSensor.
Extended color light
Hue RGB light. Behaves like a fibaro.com.philipsHueLight.
supports:
fibaro.call(<id>,"turnOn")
fibaro.call(<id>,"turnOff")
fibaro.call(<id>,"toggle")
fibaro.call(<id>,"setValue",value) -- dim value 0..100
If the value is a table the value is sent directly to the Hue light as a Hue property table.
Ex. fibaro.call(<id>,"setValue",{effect='colorloop',bri=50})
fibaro.call(<id>,"setValue",{startup={customsettings={xy={0.73500005089041,0.26499994910959}}}})
fibaro.call(<id>,"setColor",red, green,blue). -- color 0..255
fibaro.call(<id>,"changeBrightness") -- brightness 0..255
fibaro.call(<id>,"changeHue") -- 0..65535
fibaro.call(<id>,"changeSaturation") -- 0..255
fibaro.call(<id>,"startLevelIncrease")
fibaro.call(<id>,"startLevelDecrease")
fibaro.call(<id>,"stopLevelChange")
fibaro.call(<id>,"toggleDim",<boolean>) -- Toggle dim direction. true with 'stop'
The device quickAppVariable 'state' is updated with the Hue state
Dimmable light
Hue dimmable white light. Behaves like a fibaro.com.multilevelSwitch.
supports:
fibaro.call(<id>,"setValue",value) --- dim value 0..100
Color temperature light
Mapped as a Dimmable light
Color light
Hue color light. Behaves like a fibaro.com.colorController.
supports:
Room
Hue light group.
If the value is a table the value is sent directly to the Hue group as a Hue property table.
fibaro.call(<id>,"setScene",<Hue scene ID or scene name>)
Hue CLIPS devices
CLIPPresence => com.fibaro.motionSensor class='ZLLPresence'
CLIPTemperature. => com.fibaro.temperatureSensor class='ZLLTemperature'
CLIPPressure => com.fibaro.binarySwitch class='BinarySwitch'
CLIPHumidity => com.fibaro.humiditySensor. class='Humidity'
CLIPOpenClose. => com.fibaro.binarySensor. class='BinarySensor'
The startLevelIncrease, startLevelDecrease, and stopLevelChange makes it possible to bind a remote controller that support centralSceneEvent to dim when a button is held down and stop dimming when the button is released.
The lights store their Hue values in a quickAppVariable 'state'.
This can be retrieved like below and ex. used to set default startup values for Hue lights...
local function getVar(id,name) local vars = api.get("/devices/"..id).properties.quickAppVariables or {} for _,v in ipairs(vars) do if v.name==name then return v.value end end end function QuickApp:main() state = getVar(1435,"state") -- retrieve current color fibaro.call(1435,{startup={customsettings={xy=state.xy}}) -- set as default startup end
