Showing results for tags '4.062 beta'.
  1. I just bought and setup a Fibaro HC2 system and it worked well - finding it through fibaro finder, adding removing devices and accessing system from iPhone app. Then I upgraded to beta 4.062 and the following happened: * iPhone app crashes on startup, just after "loading data.." appears. Tried fresh installs multiple times from two different iPhones, both on iOS version 9.2 with same result. This happens when connecting to the local ip, when trying with remote access I get error message that home center is not found. App becomes visible in HC2 access control so it does have contact at leas
