This QuickApp contains devices of soil moisture, soil temperature and surface temperature, from accumulated temperature and precipitation data from OpenWeather via Agro Monitoring.
Soil temperature and moisture are essential indices that allow your customer to adjust irrigation work and prevent crop roots damage.
Accumulated temperature and precipitation is essential to make a right decision depends on a threshold setting. Temperature quantity index calculated as the sum of daily temperatures. Humidity quantity index expressed as the sum of daily precipitation.
Current soil data is updated 2 times a day. The soil temperature is provided in Kelvins and in this quickapp converted to Celsius (C = K - 273.15)
IMPORTANT
You need an API key and Polygon ID from https://agromonitoring.com
You need to create your Api key and Polygon ID at https://agromonitoring.com/dashboard/dashboard-start
After your registration click the "New" button in the top of the "Create polygon" screen.
Click on the polygon icon or square icon on the map.
Draw your polygon. If you choose a polygon shape icon do not forget to merge the first and last points to finish your polygon.
Fill in the "Name" field and click the "Create" button to save your polygon.
The API is free up to 60 calls per minute and a total area of polygons of 1000ha
To get the ID of the polygon, use http://api.agromonitoring.com/agro/1.0/polygons?appid=apiKey (fill in your apiKey. This will return your data in json structure. The first ID you see, is the polygon ID. Use this ID in your quickapp variable.
See: https://agromonitoring.com/dashboard/dashboard-start
See: https://openweathermap.medium.com/dashboard-update-current-and-historical-soil-data-24422fc75c5b
What is soil moisture? The science behind the measurement:
https://www.metergroup.com/environment/articles/what-is-soil-moisture-science-behind-the-measurement/
Version 0.2 (24th May 2021))
Changed Soil Moisture (child) device from multilevelSensor to humiditySensor with percentage presentation
Version 0.1 (22 May 2021)
Initial version
Variables (mandatory):
apiKey = Get your free API key from https://agromonitoring.com
polygon = Create your Polygon ID at https://agromonitoring.com/dashboard/dashboard-start or look it up with https://api.agromonitoring.com/agro/1.0/polygons?appid=apiKey
interval = [number] in seconds time to get the data from the API
timeout = [number] in seconds for http timeout
debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1)
icon = [numbber] User defined icon number (add the icon via an other device and lookup the number)
Download the QuickApp here (download the file and un-zip):
https://github.com/GitHub4Eddy/agro_monitor/archive/refs/tags/agro_monitor-02.zip
or from the Fibaro Marketplace: https://marketplace.fibaro.com/items/agro-monitor-soil-moisture
How to install:
Open the Configuration Interface
Go to Settings > Devices
Click +
Choose Other Device
Choose Upload File
Choose file from your computer with .fqa
