Showing results for tags 'button behaviour'.
  1. I've been using my Venetian blinds for a few years with just the buttons, but now decided to automate them, so I bought a Roller Shutter 3 (FGR-223 with firmware 5.1). However, I found out that by adding the FGR223 between the buttons and the Venetian blinds the working of the buttons has completely changed. The problem is: Without the FGR223, if I wanted to move the blinds up or down, I had to press and hold the down switch, until the blinds were down. Same for up. With the FGR223, I just have give a short pulse on the switch to move the blinds completely up or down. So far, it looks like an improvement. However, we also used to control the angle of the slats by short pulsing the physical switches. These short pulses are now interpreted as a command to completely move the blinds up or down, making controlling the angle of the slats with the physical switches impossible. (= very negative WAF ) So the question is: does anybody know how to control the angle of the slats with the physical buttons with a Fibaro Roller Shutter? (The FGR223 is connected to Domoticz on a Raspberry Pi via zwave-js-ui and mosquitto, but I do not think that that has anything to do with this problem, since the behavior is the same with and without a zwave controller in the network).
  2. Hi All. I want my Walli Dimmer 2 buttons 1 & 2 change the behaviour from default: button 1 switch ON, button 2 switch OFF the light To the following: both buttons switch between the actual ON/OFF state i mean, touching any button it just switches the light Is this possible?
