Showing results for tags 'roller shutter 3'.
Not sure if somone else has faced this. I have noticed that SOME of the roller shutters will open when the power comes back after a power cut. It is not consistent...meaning not with every power cut and not every roller shutter. Anyone has a clue why this happens? Or at least how to mitigate this please? I am using Fibaro HC3, Roller Shutter 3
Hi, I have a few spare unused Roller Shutter 3. Can I use them as a Single Switch to operate Solenoid Valves which have a magnetic coil which energise and de-energise to open and close? If so, any specific settings need to be adjusted? Thanks.
Hi, Parameter 150 cannot be found in the advanced configuration of Roller Shutter 3. Did anybody face such issue? Is there a way around to configure Parameter 150?
I've been using my Venetian blinds for a few years with just the buttons, but now decided to automate them, so I bought a Roller Shutter 3 (FGR-223 with firmware 5.1). However, I found out that by adding the FGR223 between the buttons and the Venetian blinds the working of the buttons has completely changed. The problem is: Without the FGR223, if I wanted to move the blinds up or down, I had to press and hold the down switch, until the blinds were down. Same for up. With the FGR223, I just have give a short pulse on the switch to move the blinds completely up or down. So far, it looks like an improvement. However, we also used to control the angle of the slats by short pulsing the physical switches. These short pulses are now interpreted as a command to completely move the blinds up or down, making controlling the angle of the slats with the physical switches impossible. (= very negative WAF ) So the question is: does anybody know how to control the angle of the slats with the physical buttons with a Fibaro Roller Shutter? (The FGR223 is connected to Domoticz on a Raspberry Pi via zwave-js-ui and mosquitto, but I do not think that that has anything to do with this problem, since the behavior is the same with and without a zwave controller in the network).
- 3 replies
- button behaviour
- roller shutter 3
Hi, I think I found clear mistake in the manual of the FGR-223 module... see pictures below and please compare the max. possible values. Picture no. 1 shows PDF version of the Fibaro manual , and picture no. 2, web version of the Fibaro manual. Unfortunately, I don't have this module (only the original version FGR-222), so I can't confirm the correctness of these parameters myself, so maybe you can help me and provide me the proper values for both of these parameters (156/157)? Picture no. 1 Picture no. 2 Thank you in advance 🙂.
Witam, Chciałbym uzyskać potwierdzanie informacji na temat różnic w ustawieniach dla parametrów dotyczących maksymalnych możliwych czasów przejazdu odpowiednio dla wersji modułu FGR-222 (Fot. nr 1) oraz FGR-223 (Fot. nr 2). Czy dobrze rozumiem, że maksymalny czas przejazdu silnika w wersji FGR-223 został skrócony... przelicznik 65535 = 655,35 sekund natomiast w pierwotnej wersji FGR-222 przelicznik był przeliczany 1:1 czyli 65535 = 65535 sekund (18h 12min 15s)? Dla ogólnych informacji obecnie używam już długie lata pierwotnego modelu FGR-222, który działa bez zarzutu i dlatego znam min. i max. wartości parametru 22. ale planowałem zakup wersji FGR-223 dlatego nie jestem w stanie sprawdzić tych informacji osobiście i nie wiem czy jest to błąd w opisie instrukcji dla nowej wersji czy może faktycznie wartości parametrów 156/157 zostały skorygowane w dół. Proszę mnie również poprawić jeżeli źle interpretuję parametr "czasu przejazdu" dla FGR-223 i nie jest on odpowiednikiem "maksymalnego czasu pracy silnika" nr 22 ze starej wersji FGR-222. INFO! Wracając jeszcze do możliwego błędu dla modułu FGR-223, to na pewno gdzieś on jest ponieważ porównując instrukcję w wersji PDF (zarówno PL jak i EN) z instrukcją dostępną bezpośrednio na stronie możemy zauważyć, że wartości dla parametrów 156/157 odbiegają od siebie (Fot. nr 3 vs Fot. nr 2) i wynoszą odpowiednio maksymalnie 90000 = 900 sekund (15 min.). Teraz pytanie do osób już posiadających ów moduł... która wersja posiada błąd 🤔? Fot. nr 1 Fot. nr 2 Fot. nr 3 Z góry dziękuję za informacje 🙂.
- 1 reply
- roller shutter 3
- roller shutter 2
Witam wszystkich. Może temat już był, ale jestem nowy i nic nie udało mi się wyszukać. Mam 8 sztuk FGR 223 w wersji 5.1 i te działają normalnie. Podnoszą i opuszczają rolety. Mam jedną od znajomego używaną i moje HC2 widzi sterownik jako wersje 3.1 i że jest to sterownik od oświetlenia. Czy da się to uruchomić by na HC2 sterowało roletą czy to już śmieć. Reset poprzez przytrzymanie włącznika do żółtego i klik nic nie dają. Podczas ponownego parowania cały czas nie widzi jako sterowonika rolet. Proszę o pomoc!
Hej, Próbuje wykalibrować Walli Roller Shutter 3 ale mam problem z mocą silnika. Mianowicie, domyślnie wykrywanie krańcówki w Fibaro ustawione jest na 10W. W spoczynku Fibaro raportuje zużycie 0.7W, w trakcie ruchu góra/dół jest to powyżej 100W, natomiast na krańcach 3W. I teraz jak ma się do tego ten parametr ustawiony na 10W? Jak zostawie domyślnie albo zmienie na mniej (5W, 3W, 2W, 1W) to efekt kalibracji jest taki, że roleta podjeżdza do góry i się zatrzymuje a kalibracja nigdy się nie kończy (biały pierścień LED mruga non-stop). Dopiero jak przestawiłem wartość parametru z 10W na 100W to zadziałało... Ktoś miał coś podobnego? Może źle rozumuje ten parametr? Pozdrawiam, W.
- 1 reply
- walli
- walli roller shutter 3
Hi everyone. I have a number of Roller Shutter 3 modules. All worked fine for a year or so. Now one lost connection but it still works when I physically press the switch button. Although it takes approx 2 seconds before the shutter starts moving (irrespective of whether it is to go up or down). Previously it was instantaneous. Likewise all other roller shutter modules work instantaneously (when I physically press switch button or via app). In the Fibaro app and via Home Centre 2 this roller shutter module is disconnected and waking dead nodes doesn't do anything. Any idea what might be the issue here? I checked and all cables seem connected. Thanks.
Zachowanie Roller shuttera 3 niezrozumiałe przy kalibracji, po dodamiu urzadzenia suwak działa prawidłowo po zmianie na bramę garażow z pozycjonowaniem prosi o kalibrację. Wciskajc ikonę kalibracji roller przeładowuje interfejs w ligach leci że zraportowano nieznane położenie rolety i cisza nic sie nie dzieje, wymuszajc kalibracje na parametrze 150 rusza w jedna stronę log [22:56:31] ID 402: Otrzymanie raportu parametru nr 150, wartość = 1 [23:06:21] ID 402: Otrzymanie raportu parametru nr 157, wartość = 304 I zatrzymuje sie być może osiaga krańcówkę, i poowinna iśc w druga stronę, niestety nie wykonuje funkcji, próba zmiany suwaka w skrajne położenie daje log . 22:57:54] ID 402: Application rejected request Po probie ponownego wciśnięcia kalibracji log przesuwajc suwak słychać ze przekaźnik załacza [22:59:53] ID 402: Zaraportowane nieznane położenie rolety, proszę przeprowadzić kalibrację. Roller podłczony na stole, bez przycisków, silnik w pełni sprawny 150w poboru. Parametr 151 pozycja 0 by wykluczyć przeciażenia. Chciałem zmienić z 2 na 3 bo potrzebuje wiecej funkcji dla bramy suwanej, gdzie RS 2 działał idealnie podłaczajc RS3 same problemy. HC2 4.530 Roller shutter FGR-223 ZW5 v5.0
- 4 replies
- roller shutter 3
- fgr-223
Roller Shutter 3, scene to stop a running roller shutter
AOV posted a question in Scenes and Interface
On my roller shutter 3 I don't have a wired switch. Therefore I bought an Aeotec WallMote Quad. Scenes for opening and closing is not a problem and moving to certain positions as well. I have a Zipatile 1. I need a scene that stops the roller shutter 3 from running or even better: on button pressed check if the roller shutter is running and then stops the shutters. I've tried the example in the attachment, but it doesn't work. Any suggestion? Thanks!-
- scene
- stop shutter
Hi Fibaro community, I have HC3 and RS3 set as "blinds with positioning" (not venetian blinds). In the desktop browser interface, in the device preview, it is possible to set "Favourite Position". See attached pictures 1 and 2. (button with star). I have set the "Favourite Position" to position 25%, where my roller blinds are closed, yet with hole-gaps for the sun to come through. 0% would be fully closed (dark room). 100% is fully open. Does anyone know how this position can be called or used in scenes? In the desktop browser interface it works, however is quite useless. I doubt someone would be controlling his devices from the browser interface. I also went to have a look in my iOS app and there is a special button ("III" symbol, see attached picture 3). I hoped this would be the "favourite position" button. However this button does the same full close as the close button. Does any of you know what is the meaning of this "III" button? Thank you, Peter
- 1 reply
- roller shutter 3
- rs3
Dear all, i am about to start the installation of my HC2 system. The Main moduls in the beginning are the RS3 to operate all electrical exterior blinds. Our electrician did install one RS3 in order to see what happends. With surprise we discovered, that without having an HC2 in operation the blinds won’t work anymore. So, that doesn’t really concern me, but I wonder if you’ve got a tip for me, how i can get all 21 RS3 integrated /“learned on” to my system while having the HC2 placed in my server rack in the cellar?!?! The reason I am asking are the many comments that it is necessary to have the HC2 close to the modul when learning on. Is there a way arround? As the RS3 are being mounted next to the windows spread over three levels around the house. Thank you and greetings from Germany. Markus
Associate other devices with Roller Shutter 3
AndreJacomeSilva posted a question in Roller Shutter 3
Hi all, I've upgraded a couple of my blinds from the Roller Shutter V2 to Roller Shutter v3. Everything worked properly (after some initial problems) and I did manage to calibrate. My problem now relies with the association of a FGR-222 button and the Roller Shutter 3 (FGR-223). As I've done multiple times, I created the association group 2 (assigned to the second switch connected to the FGR-222) to both blinds and additionally I set the parameter 15 to the value 1. «Parameter No. 15 - Operation of the Dimmer and Roller Shutter Controller - enabling this option allows the user to dim lighting/shut roller by associating Dimmer/Roller Shutter Controller and holding or double press of double switch (only mono-stable switch). 1 - Dimmer/Roller Shutter Controller control is active» Although this setup works well with the Roller Shutter V2, I cannot have it working with Roller Shutter V3. Does V3 uses different endpoints?
