Showing results for tags 'stop shutter'.
  1. On my roller shutter 3 I don't have a wired switch. Therefore I bought an Aeotec WallMote Quad. Scenes for opening and closing is not a problem and moving to certain positions as well. I have a Zipatile 1. I need a scene that stops the roller shutter 3 from running or even better: on button pressed check if the roller shutter is running and then stops the shutters. I've tried the example in the attachment, but it doesn't work. Any suggestion? Thanks!
