Showing results for tags 'bypass 2 fib_fgb-002'.
  1. Hi, having problems with my setup: Fibaro Dimmer 2, Bypass 2 and 24v transformer attached to a 25w Led strip. I cannot dim it properly, even though i can turn it on and off with physical button (not from fibaro interface)... without Bypass 2 nothing worked. The trafo is a LT2436FAS this one and the strip a 10w/m, 2,5m long. LED strip I got recommended this setup from the shop. Dont know what to do to solve this, can anyone help me out here? Regards.
  2. I have two Dimmer 2 modules but after trying to install them realised I need a bypass so ordered two Dimmer Bypass 2 FIB_FGB-002. The supplier initially said there would be a two week wait but now have no confirmed date as they haven't been released by the manufacturer. I checked with another supplier and they said they thought there was an issue/delay with certification. Does anyone one know when these might be available in the UK?
