Showing results for tags 'led-strip'.
  1. Hi, having problems with my setup: Fibaro Dimmer 2, Bypass 2 and 24v transformer attached to a 25w Led strip. I cannot dim it properly, even though i can turn it on and off with physical button (not from fibaro interface)... without Bypass 2 nothing worked. The trafo is a LT2436FAS this one and the strip a 10w/m, 2,5m long. LED strip I got recommended this setup from the shop. Dont know what to do to solve this, can anyone help me out here? Regards.
