Showing results for tags 'dimmer-2'.
  1. Hello: I think that my scenario is very common, but I can't find or can't understand how to wire it. In the junction box where I'm installing the Dimmer 2 (FGD-212) I have Live, Neutral and the end of a 4-way switches circuit that works with Live. My switches are toggles, not potentiometers (wheels). I want to dim the light only remotely and to use the physical switches to turn the light on and off. I see no reason to power my switches from Sx. I can't understand the 2-wire or 3-wire schemas in the manual. Why is Neutral connected to Sx sometimes? Isn't Sx the Live output for the switches? Can I power the switches directly from Live and then feed S1 with it? See the attached schema. Thank you!
  2. Hi! Recently we had an electrian over to install LEDs in the kitchen. However, I came a little late, and the push dimmer (in socket) from Eltako (EUD61NPN-UC, supports up to 400W) was already installed when I got back home. Of course I would like to replace it with a Dimmer 2 but I got worried about a line: ref: http://manuals.fibaro.com/dimmer-2/ The LED that was installed is from a Swedish company called UniLumLed. I guess it's some kind of branded light that probably exists under different names. It should consume ~8W with LED and transformer (spec). It's dimmable. What do you think – can I replace the current Eltako with a Dimmer 2? Thanks in advance
