Showing results for tags 'double click'.
  1. Is there a way for a scene to trigger each time a push button connected to the S2 input on a dimmer with the scene activation setting enabled is activated? I can only seem to trigger the scene when the sceneActivation state changes. ie: double click after single click. I'm trying to setup a sensor override push button where the following should occur: single click = toggle light (on/off) + enable sensor override hold = start dimming light + enable sensor override release = stop dimming light double click = disable sensor override When the sensor override is disabled, the motion sensor will have control of the light. Cheers.
