Showing results for tags 'event panel'.
Found 4 results
  1. I have serious trouble with an unstable HC2, for no rational reason I can think of. Event panel has gone from slow and not working with data from yesterday or filters. To now completely empty/unresponsive (see image). Someting is corrupt in the database(s) I think, and I haven't seen anything like this in my 3y with HC2. Is it time for a hard reset, removing all devices & scenes and build everything from scratch again - or are there tools and methods to restore or remove bad records etc.? Restarts don't change anything. Plenty CPU and RAM.
  2. How can I write something to the event panel from a scene, which is only modifying global variables but not changing the state of a physical device? I do have scenes which now and then change the value of a global variable. To do this, I would like to have a text line in the event panel. SMS, e-mail or push works fine, but that is a total overkill and not needed for this. A simple entry in the event panel would be nice. any clue? thanks for tip and tricks. maybe another VD? but how should this be done?
  3. Not all devices show up in event panel. For instance some D/W sensors are missing, some Danfoss valves are missing... They are configured exactly the same so I'm puzzled.
  4. Dear fibaro team May I suggest you an improvment for the event panel... When I select a set of devices to display their events and I change date range, it should be pleasant to keep the set of devices I selected. Today, when I change the date range, others devices are selected (I don't understand on which criteria !!!). That means if I select a wide date range and all the devices are automatically selected by HC2, it take a long time to display event (when it doesn't freeze the interface !!!) Thanks a lot David
