Showing results for tags 'fgms-001-zw5'.
  1. Hey peoples... I'll try to keep this short. - Purchased a total of FGMS-001-ZW5 Zwave Plus Multi Sensor - Both worked great - One decided to kill batteries fast - Returned it to AARTech, they gave me a replacement - The replacement comes up as a "Aeon Multisensor" in SmartThings - Tried multiple times to REMOVE / ADD - Even done several hard resets to the sensor - Still comes up as an "Aeon Multisensor" - Tried force/change the device handler to the "Fibaro Motion Sensor ZW5" model, MOTION is always "ON", nothing else shows up in the SmartTh
  2. Another Fibaro rookie here, so guessing my questions likely fall into the noob category. Anyway I´ve just finished building a house and went "all in" with Fibaro. A whole bunch of dimmers, switch relays, wall plugs, smoke and motion sensors tied together with HC2. LUA is on the todo list to learn since I have realized it will be needed to create the kind of scenes I am thinking of.. But to the first question.. I have been making some scenes which are triggered by the motion sensors. However they are far from reliable, and my guess is that one of the reasons is that the mo
