Showing results for tags 'fgs 223'.
  1. Is it possible to disable the Association between the S1 switch and the Q Relay? i want to use S1 / S2 for signal to my server, and to let Q1/2 be controlled by the server only.
  2. Hello good morning, I have seen errors in the FGS223 that handle certain lights, I appear as WAITING FOR WAKEUP. I have updated the firmware version to 4.51 and the problem persists, do you have any idea what it could be? Only the problem appears in some of the relays, not in all. Greetings.
