Showing results for tags 'fibaro home center'.
  1. Hello dear Fibaro Users & developers, I am experiencing an issue with my HC3 while making API calls to another system in my network, Domoticz. Who has the same experience or solution to resolve this? The Issue: I created a scene in the HC3 that includes program code to make an API call to Domoticz. However, the API call does not work as expected. To verify the code, I tested the same API call outside the HC3 using curl commands, and it works flawlessly. Each time I activate the scene, I see the following error in the Domoticz system log: 2024-12-16 23:37:36.517 Status: [WebServer] Deprecated RType () for API request. Call ignored, please use correct API Command! (192.168.xx.yyy) < We an say that te network connection between both systems is correct. Otherwise Domoticz can not log the incomming API call > Additional Details: When testing Domoticz without the HC3 making API calls, everything works correctly. It seems the HC3 may be sending an invalid or deprecated request parameter (e.g., RType). My Domoticz system is running the latest version, and the HC3 firmware is up to date (v5.170.16).
