Showing results for tags 'fire alarm'.
Found 3 results
  1. Hello guys, Is there any idea how to add other z-wave fire alarm device to HC2? I am having First Alert smoke/co alarm which I tried to add but unsuccessful. Please help. Fyi, HC 2 Software Version:4.110 Thank you.
  2. Hi, I recently installed three smoke detectors (from Popp) which are included perfectly (I think) and should then be linked. But I am a bit confused about how Fire alarms are supposed to be set up in an HC2 system. In contrast to a burglar alarm, fire alarms are always on! Disarming the fire alarm is not generally something you would like to do. I set up an alarm functionality for a flood sensor by setting up a push notification message and then set that to be sent (+ email) on a state change of the device (in the advanced panel). Is this how one should handle smoke/fire alarms too?
  3. Hi, I have recently installed 6 smoke sensors spread around the house with a HC2 and various other modules, I cant find another forum topic with this, so maybe I'm missing something obvious. Is there a way to interlink the smoke sensors, so when 1 detects fire, they all activate their sounders? Thanks in advance
