Showing results for tags 'first installtion'.
  1. Good evening everybody, I am new to the Home Center 2. Before today I used a Raspi 3 with "Home Assistant" and I have quite a few z-wave devices, like the Fibaro Roller Shutter 2, Fibaro Motion Sensor and so on. Since the whole "Home Assistant" thing did not work out 100% with all z-wave devices (problems with Sensative Strips binary mode, Motion Sensor, z-wave USB stick crashes) and it is also pretty uncomfortable to configure, I decided to go the Fibaro Home Center 2 way. Since I am pretty impatient I ordered the Home Center 2 from Amazon prime-now same day and just got it delivered. After unpacking and connecting to the router I receive a "503 error - server unavailable". I rebooted everything and still the same. Things I tried: - empty caches, using different browsers and computers - recovery - even it should be on factory settings anyway - disconnect a couple of minutes from power - reboot Fritz!Box (using a 7590) I spent now 3 hours and I still have not seen any login screen. Very frustrating! Oh yes, the leds: the right 3 ones are on, the "update available" is blinking. Any ideas from someone beside sending it back to amazon? Regards, any help appreciated, Marc
