Showing results for tags 'floor heating'.
  1. I'm interested in using the fibaro z-wave thermostat on our floor heating system. I got two questions: -The manual says that the termostat must be mounted horisontally. Why is that? -The termostat will be mounted in the floor heating central and not in the room it will be controling. I will place a temperature sensor in that room and connect to the thermostat. Will that work? Our floor heating has 8 circuit for 8 different areas/rooms each one controled with one thermostat. Its an wirsbo/uponor RWG system from 1991. To be able to fit the fibaro thermostat to the valve i will use an M28 to M30 adapter.
