Showing results for tags 'google assistant'.
Security setup for using Google voice control to open garage door
liptsin posted a question in Google Assistant
Hi, I've setup my HC3 lite with a Smart Implant to open my garage door including using a limit switch to send me notifications when it's opened. I've also linked it to Google home and have open it via voice control without problem. (apart from the occasional times when Google says it's not available and suggest to set it up again, even though it opens it or turns on devices) Anyway the issue I've with this setup is the security where anyone can just ask Google to open my garage door. Chances might be slim that someone would be shouting outside my house hoping that Google home picks up and the garage door. But I would like to eliminated that chance if possible. Any idea or suggestions would be much appreciated. Thank you- 1 reply
- google assistant
- voice control
Can't Operate Some HCL Scenes from Google Assistant
Eamonw posted a question in Scenes and Interface
Good Day All, I'm new to Fibaro and have purchased a HCL on the confirmation from Fibaro support that it would wllow me to Open and Close Fakro Windows and Blinds through Google Assistant. I've have limited success with this and queries to Fibaro support have been met with stonewalling after the sale was made. They pointed me to the help files, which are not the easiest to follow and are inconsistent but none the less, it seems as if all is set up as required by Help. I cannot get the Hey Google, talk to Fibaro command to work. The boomy Fibaro voice cannot find any devices. It can find the HCL, but noting attached. Support did say that this was due to the fact that they are "security devices" ? A Window Blind? Stonewalling I think. Hopefully someone here may have encountered something similar and knows a solution? Attached is a screenshot of the 4 scenes I have setup in HCL Next are two screen shots showing the configuration of Blinds Evening which is similar to Blinds Morning – both of these scenes are visible in my Google Assistant and I can successfully activate them by saying “Hey Google, activate Blinds Evening” for example. Blinds Evening and Morning are created using Graphics Blocks while Blinds Open and Close are created using Magic Scenes. Next are screen shots of the Blinds Open scene (which is the same as Blinds Close except reated using Magic Scenes) – these do not show in Google Assistant - Can't figure out why. As you can see below, the Blinds Evening and Blinds Morning Scenes show up in for Google Assistant but not the Blinds Open or Close. Even if I copy the existing Blinds Morning or Blinds Evening Scenes (created using Graphics Blocks), giving the copied instances a new name, they still do not show up for Google Assistant. Lastly is a screen shot of all my devices: Here are examples of the configuration of 1 each of the blind and Skylight The scenes I have set up for morning and evening trigger all blinds from the HCL itself. My goal is to be able to activate Blind 1 – 4 (open & close) and Skylights 1 – 4 (open & close) - all individually from my Google Assistant through voice by saying “Hey Google, open Roof Light 1” for example. Has anyone cracked something like this before? Any tips are appreciated. Regards, Eamon.- 3 replies
- hcl
- google assistant
Hi community, Perhaps you can help me understand how (if) to connect two houses that each has a HC2 and have them connected to my Google Home Mini for voice control. Setup I have two houses, in each house I have a HC2 that are linked to my Fibaro Cloud account. I can access them both remotely and everything is working fine through the app on my phone and as well as from computers. In each house I also have a Google Home Mini, that are configured to talk Swedish AND English. I live in Sweden should I say as well. Problem I've managed to link my Fibaro account to the Google Home app on my phone but only the devices in ONE of the houses are SEEN and can be controlled trough Google Home or Assistant. I've done multiple unlinking and re-linking as well. Both HC2's are on 4.510 I can switch to English and say "talk to Fibaro" and it lists both devices and I can control them from there. But through the Google Interface only the devices in one of the houses are seen - if you follow me here Any guidance or ideas to test would be highly appreciated! Have a good Saturday out there!
- 3 replies
- hc2
- google assistant
