Showing results for tags 'heat controler'.
Found 3 results
  1. Hi, I'm a new user of the Fibaro ecosystem and I'm facing some issues. One of them has to do with controlling the heat in my home. I have setup zones - 1 per room, and each zone contains 1 Heat controller. I have a HC3 and I see there are several ways in which you can control the temperature - from the Heat Controller directly, or through Zones. I tried working with the temp view in the website (/app/climate/temperature), but also with the mobile app through manual settings on the thermostats. Anyway, in the end I did "back to schedule for all" and my zones show up OK: You can see Living Room set at 24C. However, if I go to the climate view under settings, the thermostat for Living Room shows up as 26C (an older value set via the mobile app BEFORE choosing "back to schedule for all"). This is really odd to me. I'm curious 1. if I'm encountering a bug and 2. what is the "recommended" way to handle temp control in HC3? Thanks! Mihnea
  2. Hello, I need a help. I can see more ways od forum and marketplace for override heating zone, but they are to complicated for me. I need simple scene (or virtual device??) which will set all heating zones to specific temperature for specific time and after that back to schedule. Why I need this? I have central heating system with wood and water acumulation puffer. Sometimes temperature in system increase to high and for security reasons I need to cool down system. I made scene which control temperature in system and send me notification when temperature is too high. Notification ask me if I want to run some scene. Here I want to open all radiators. Or, if somebody have another idea, maybe I don't need override heating zone. I have Fibaro heat controller on all radiators, but I don't know how to open it to max with scene. Thank you in advance.
  3. Witam Jak zamontowałem głowice działała ręczna funkcja powrotu do harmonogramu po zmianie temperatury tj. po przytrzymaniu dłoni na głowicy powracała z ustawionej manualnie temp na tą z harmonogramu teraz dziadostwo automatycznie zamyka zawór (biały kolorek). Wszystkie głowice mi się tak zachowują. Mam pytanie czy mam zwidy czy to ktoś może potwierdzić ? ps. co do tematu temperatur czujniki swoje a głowica swoje zimno jak w psiarni temperatura na 21, czujnik wskazuje 20 a grzejnik zimny.
