Showing results for tags 'icons is missing'.
  1. A few days ago I found a first generation UBS in an old box and I decided to use it. The UBS is connected to two DS18B20 sensors that I have mounted on my underfloor heating pipes. After that I included the UBS in the Z-wave network and the sensor readings look great. However, the HCL GUI is showing some other weird things (with corresponding icons) : 3x motion sensor and 1x remote control ... There is no icon similar to the UBS circuit board (I also checked the master device) Does anyone know what is causing this? Thanks!
  2. As a result of my HC2 did not restart automatically after a power failure, I tried to reconfigure the HC2 with the function recovery. I updated succesfully afterwards to software version 4.100 which I had previously used and reloaded my latest backup. It all went according to the plan but all my uploaded pictures of my rooms and all my uploaded icons were overwritten with an error symbol. Can it really be true that HC2 does not save your own pictures and icons on USB key?
