Showing results for tags 'modbus tcp'.
  1. Version 1.0.0
    61 downloads
    VD - Switch CCGX Relais .lua A VD that can switch the AC-Out2 relais of the Victron inverter One can not directly switch the Quattro relais, therefore I used the “Venus GX Relais 2” (currently NOT used) and connected it to the contacts of the “AUX inputs of the Quattro inverter and you have to install an assistant on the Quattro to do the final switching o the Relays.
