Showing results for tags 'venus gx'.
Found 5 results
  1. Version 1.0.0
    41 downloads
    VD-Venus.lua Extracts all info from Unit ID 100 -- READ Venus Register 840-846 UNIT ID 100
  2. Version 1.0.0
    45 downloads
    VD-Solar-Charger.lua This extracts all available information from the MPPT charger. -- Unit ID Instance in VRM -- 245 258 Venus GX VE.Direct 1 port (ttyO2) -- 243 260 Venus GX VE.Direct 2 port (ttyO4)
  3. Version 1.0.0
    30 downloads
    VD-Quattro.lua -- READ Venus Register 3-63 UNIT ID = 242
  4. Version 1.0.0
    24 downloads
    VD-BMS.lua This is for Canbus BMS I have a BYD Battery monitor. Most of the Registers are have only "0" valiues and I extracted only what I found having some values. -- Unit ID /DeviceInstance Remark -- 225 512 CAN-bus BMS
  5. Version 1.0.0
    61 downloads
    VD - Switch CCGX Relais .lua A VD that can switch the AC-Out2 relais of the Victron inverter One can not directly switch the Quattro relais, therefore I used the “Venus GX Relais 2” (currently NOT used) and connected it to the contacts of the “AUX inputs of the Quattro inverter and you have to install an assistant on the Quattro to do the final switching o the Relays.
