Showing results for tags 'restore dead device'.
  1. If I restore a dead device connected to the HC3 through the mobile app. Then the device recovers immediately after the push of the button. But if I do the restore by code (in a HC3 QuickApp) then the device does not restore. I use (wakeUpDeadDevice(deviceID)) for this. local parentID = 201 fibaro.wakeUpDeadDevice(parentID) fibaro.sleep(1000) fibaro.call(parentID,'turnOn') Is there any other code similar to the code the mobile app uses?
