Showing results for tags 'smart locks'.
  1. I recently got the august smart lock pro (3rd gen) and I'm trying to include it in my z wave network. After I put the home center into learning mode to add a lock and use the August app to activate the lock's z wave chip... nothing happens. the app says I should continue setup on my hub's ui but the learning counter keeps going down and it doesn't show that it's configuring any devices. did anyone succeed to include this specific lock?
  2. It would be extremely useful if the Z-Wave Deadbolt from Yale (which seems to be the most popular) could have the correct set up and templates in HC2 that you can otherwise get in Vera. I am desperate to incorporate this into my system ASAP - could you advise if this is something we will ever see happen? To illustrate the functionality available with these locks in Vera - please see this video - (Between 3:00 - 6:10 is the real functionality I am talking about) If there is any lock that is supported by HC2/Fibaro in the same way then please suggest Thanks!
