Showing results for tags 'smart switch'.
I have a smart switch 6 made by AEOTEC. It took several attempts to add it correctly in HC2. Once it did it added the switch and a Volt and Amp meter. The Amp and Volts work just fine but switching the switch on and off does nothing. to turn it on and off I have to press the action button on the switch. even if I do that the status does not change on HC2. Can someone explain what is wrong? Fibaro bug? I know there has been some issues in the latest versions with parameters but I don't see why it would cause this issue. *Note when I added it on my first several attempts it would sa
- 5 replies
- 1
- aeotec
- smart switch
- (and 6 more)
Aeotec Smart Switch - How is yours configured ?
AutoFrank posted a question in Other Devices / Third-party devices
Hi, I was recently told by fibaro support that my aeotec smart switch was one of the busiest in the zwave network. My was excluded from polling so I wanted to see how people had set theirs up and if they changed the default values This is how mine is setup and I was wondering if anybody had some tips Polling : Exclude from global polling Parameter 3 Current Overload Protection Load will be closed when the Current overrun (US: 15.5A, other country: 16.2A) and the time more than 2 minutes 0 - disabled Parameter 20 Output Load Status Con -
Hey! Anyone have experience with the Aeotec Smart Switch 6 and HC2? Does it work and does it have templates?
- 7 replies
- aeotec
- smart switch
