Showing results for tags 'temp sensor'.
  1. Hello everybody, I have installed the temperature sensors to my already working system. I added the DS18B20 to the window and door sensors. So all the door and window sensors are configured and used in the HCL system Question is now, which reconfiguration is needed to get the sensors visible as active devices? Soft reconfigure device? I would prefer this one, so I do not loose all the scenes and VDs using the window sensor Reconfigure device? The brute force way, removing and adding the z-wave device? I hope this is not needed thanks for advice kuno
