Showing results for tags 'touch control'.
  1. Wondering how to integrate 2 different worlds that are often connected, home automation and intercom/doorphone? Just in case someone is interested in combining YUBII or FIBARO hubs with IP video intercoms to control the home automation, I attach the following document as a how to guide with FERMAX MEET IP System. FIBARO_MEET_IN_rev1.pdf CASE STUDY-TEC-FIBARO_1.2_EN.pdf
  2. Hi, I wonder if anyone has had any experience using the Fibaro RGBW control puck with a wall mounted touch control? I wanted to achieve installation of wall controls such as this one: https://www.superbrightleds.com/moreinfo/controllers/wall-mount-touch-color-rgb-controller/1484/3480/ In parallel with the Fibaro RBW controller, so that manual operation of the lights (strip) and Ipad control can be made active. An immediate issue I see is that the voltage signal from the Fibaro would back feed into the wall control and visa versa. One interfering with the other. Since both devices are designed to do the same thing. Since it is DC voltage I had thought about diodes (no pun intended) but surly someone here has already asked this question or at least been down this road. Would appreciate any feed back, help or ideas please.
