Showing results for tags 'virtual dimmer'.
  1. Hi, In my HC2 setup I have few LED strips connected to RGBW devices and of course few devices in panel to control each strip separately. I have associated button click with all 7 devices to turn light. Moreover I have virtual device to control strips in different groups set. Right now I would like to be able to control those lights also from Alexa ( will be using HA Bridge ). Correct me if I`m wrong but above is not enough to control light via Alexa. In my opinion I need something like Virtual Switch as Dimmer under which I will have X LED strips assigned. It should allow to create link for HA to turn On / Off and Dim. Question is: How to create such a Virtual Dimmer?
