Showing results for tags 'virtual switch'.
  1. Hello, I would like to create a virtual switch (a switch which is not a device itself) to trigger certain actions. So far I use a scene for this, but from a user perspective I prefer a switch (for example: main light switch, which turns on or off a certain number of lights) I have used Domoticz before (great software, but i had a problem with the stability of the network and the smartphone app was so and so) and there this was very easy to create. Many thanks and all the best Kai
  2. Hi, In my HC2 setup I have few LED strips connected to RGBW devices and of course few devices in panel to control each strip separately. I have associated button click with all 7 devices to turn light. Moreover I have virtual device to control strips in different groups set. Right now I would like to be able to control those lights also from Alexa ( will be using HA Bridge ). Correct me if I`m wrong but above is not enough to control light via Alexa. In my opinion I need something like Virtual Switch as Dimmer under which I will have X LED strips assigned. It should allow to create link for HA to turn On / Off and Dim. Question is: How to create such a Virtual Dimmer?
