Showing results for tags 'water flow'.
  1. This QuickApp gets the actual water level or flow from rivers in France. The latest water level or flow of your selected hydro station is updated in the value of this QuickApp. You can choose between Water Level or Water Flow. If you want to measure both, simply install the QuickApp twice. See for more information: https://www.vigicrues.gouv.fr Service d'information sur le risque de crues des principaux cours d'eau en France Version 1.0 (25th April 2021) - Added Water Flow next to Water Level, mode = level or flow (Choose for waterlevel or waterflow, default = level) - Added debugLevel (Number (1=some, 2=few, 3=almost all, 4=all) (default = 1)) - Re-structured the code Version 0.5 (16th August 2020) - Error message instead of debug message in case of error - Adjusted the date/time in the label and debug message. If the json file was in a different order, a wrong date/time could show. - Changed method of adding QuickApp variables, so they can be edited Version 0.4 (7th August 2020) - Changed debug message actual level with location - Added QuickApp variables Version 0.3 (3rd August 2020) - Put the latest WaterLevel value in QuickApp value - Put the latest DateTime value in the QuickApp log - Added labels with the json data - Added debug notification Version 0.2 (3nd August 2020) - Date time value converted to readable time - Added the latest date, time and waterlevel values QuickApp variables (mandatory, they will be automatically added with the default values): - stationHydro = Status from where you want your data from - mode = level or flow (Choose for waterlevel or waterflow, default = level) - interval = Number in seconds to request the data - debugLevel = Number (1=some, 2=few, 3=all) (default = 1) Download the QuickApp here (download the file and un-zip): https://github.com/GitHub4Eddy/water_flow_level/archive/refs/tags/water_flow_level_10.zip or Fibaro Marketplace: https://marketplace.fibaro.com/items/water-flow-level How to install: Open the Configuration Interface Go to Settings > Devices Click + Choose Other Device Choose Upload File Choose file from your computer with .fqa
