Hi there
Altough some people are getting the zwave.me keyfob to work, I tried several methods, but it does not seem to activate my scenes.
I have the ZME_KFOB2 (Version 1.4*)
*With 1.3 you can add the device holding the four buttons for 5 sec. and push then button 3
*With 1.4 you can add the device holding the four buttons for 5 sec. and push then button 1
I just want to start a scene when I leave the house en start another scene when I come home.
I included the device and also woke up the device.
I also was able to configure the parameters so that I can start a scene with button 1,2,3,4
However when configured the following scene, nothing works.
Controller = Fibaro HC2
214 = device ID Keyfob
159 = light scene on
160 = light scene off
Scene 1
%% properties
214 sceneActivation
%% globals
if ( tonumber(fibaro:getValue(214, "sceneActivation")) == 11)
then
fibaro:startScene(1);
if ( tonumber(fibaro:getValue(214, "sceneActivation")) == 12)
then
fibaro:startScene(160);
if ( tonumber(fibaro:getValue(214, "sceneActivation")) == 13)
then
fibaro:startScene(159);
if ( tonumber(fibaro:getValue(214, "sceneActivation")) == 14)
then
I also tried the following scene
Scene 2
%% properties
214 sceneActivation
%% globals
-- This part makes sure that the script only runs once
if (fibaro:countScenes()>1) then
fibaro:debug('Kill the second scene!');
fibaro:abort();
RemoteID = 214; -- Change this number into your remote ID number
if ( tonumber(fibaro:getValue(RemoteID, "sceneActivation")) == 11) -- button 1, single press
then
fibaro:startScene(159); -- Fill in the number of the scene you want to activate
if ( tonumber(fibaro:getValue(RemoteID, "sceneActivation")) == 12) -- button 2, single press
then
fibaro:startScene(160); -- Fill in the number of the scene you want to activate
Any advice?
Thanks in advance!
