Showing results for tags 'zrc-90eu'.
  1. I'm using a ZRC-90EU and everything works fine but I don't like the way I need to assign a action to a button (function). As you can see in the picture, in the Advanced page of the device you can assign an action to each button but you have to start from scratch every time (I can not assign an existing scene to a button).... With a block scene it is possible as well but if you want to assign 1 function/scene to one button and you know that every button has 4 options (1x,released, held and 2x) than I have to create 32 scenes.... I am new and have a HC3 so I never had HC2, HCL .... but once I've seen a LUA script that contained all button options and in the script it was possible to assign a function/scene to every possible option per button within that script so you could assign existing scenes as well. I already tried some HC2 LUA scripts and they don't work in HC3 so copying the script from HC2 isn't an option (+ I can(t find it anymore ) Does someone have a solution so I can use a LUA script or a QA to assign functions/scenes to the buttons without creating a new scene per button .... ? Thank you
