Showing results for tags 'zwave valve'.
  1. Hi all,Has anyone done this?Fibaro HC2 + Nest + Z-Wave Danfoss Radiator Valves?Is the Fibaro able to control the temperatures in different rooms via the valves as well as then have the Nest functionality? In my flat I have 10 radiators flowing hot water for 10h a day. Heating is centralized the only thing I can do is open/close valves. Or would I be better adding a z-wave thermostat and z-wave valves in each room? Does nest being able to control each room then ?Any input valued
