Showing results for tags 'zxt-600'.
  1. Hi, I'm trying to configure ZXT-600 with my HC3 but I have some challenges/bugs. *Disclaimer - at this moment I'dont want to use any specific AC. I'm doing this as a "dry run" before final installation 1. HC3 without any problem recognize ZXT-600 "devices". ZXT-600 is wotking wit USB power adaptor. 2. I'm trying to configure ZXT-600 based on manual (https://1d7d2411-2e94-4f8c-a95f-87afc2c677d4.filesusr.com/ugd/6dacfa_70e9d19869b44299b27f501fd1673f85.pdf) . At the beginning I added two parameters: - 27 [Set IR Code number from built-in code library 27 (0x1B)] - I choose one of the Mitsubishi - 30 [Set Auto Report Condition Trigger By Room Temperature change 30 (0x1E)] - I choose value what menas based on manual "Auto report if room temperature is different from last report. 1(0x01) = 1°F (0.5°C)" ZXT-600 has been assigned to room Kuchnia/Kitchen (details on below print screen) I used iOS Fibaro application for HC3 and it looks that HC3/ZXT-600 doesn't work ijn proper way. 1. Even when I'm using parameter "Auto report if room temperature is different from last report. 1(0x01) = 1°F (0.5°C)" temperature doesn't change. Mobile application and Fibaro HC3 dashboard present one value (updated during power adaptor has been detached/attached) Is it a bug, malfunction or my lack of knowledge how to configure devices ? 2. I assume that should be possible send IR commnad (on, off, cooling, heating ...) from mobile application->HC3->ZXT-600 to air condition IR receiver. Maybe I'm wrong or I miss something. Unfortunatelly I haven't or I can't see any places in mobile/web applications where I could be do this Please let me know about your thoughts/experience. Thank you
