Compatibility with Horstmann thermostat and EZ Motion 3in1
lumel
Using my HC2, I see that Everspring products are supported by system, but not my thermostat Horstmann HRT4-ZW and relay ASR-ZW, and EZ Motion 3 in 1 triple sensor.
System detects this products but they are not working, there are not possibility to use them in scenery, etc..
These products will be compatible in future?
Thank you!
Mario
  • Answers 67
  • Created
  • Last Reply
Guest ericf
Seems that the polling value for the input poling is no anymore available in General or Advanced tab ????
It seems to pool a lot ... every x (very short like 5 minutes) the status ... as it uses standard battery they will be out after some ... hours/days ...
Guest Adam
If you update soft 1.020 you must reincluded EZMotion to best implements.
Parameters to EZMotion we add in soft 1.021.
Polling you can change for options [wake up interval (s):]
Guest ericf
regarding : Polling you can change for options [wake up interval (s):] what is the parameter ?
or only available in 1.021 ?
Guest Adam
all possible parameters for EZMotion we add in soft 1.021
If you change polling of the EZMotion. You can change value in device configuration General -> Wake up interval (s):
Guest ericf
so I need to wait 1.021
Guest ericf
I have the message 'Dead Node' ... why ?
I receive back info when I click on the bleue button on the module.
Guest Fidziu
Dead node means that:
HC cant find this device but know that this device should be reachable. Because its still in routing table.
HC will try to find it by searching whole mesch but it can take couple hours.
Most reason of this is:
Device not in range or lost range.
Device not powered.
Device is broken.
HC will skip commands to that device to avoid lags on z-wave network. If it will find this device again it will rebuild routing table and try to find couple alternative routs.
Guest ericf
the device is at 1 meter on my desk ... near the HC2. I click on the blue button to sync with the HC2 ... and seems the battery are working.
Guest hotrot_net
I 2 have problems with the 3 in 1
Temp not correct
Keeps set to montion detect altough its placed in a box.
Guest ericf
for the temp same for me ... sometimes -13 in my office
/emoticons/default_laugh.png" alt=":lol:" />
Guest hotrot_net
Not only the 3in1 problem
this is a everspring SP814-1 with a scene Alarm this is not working the sensor detecs motion but the HC2 is not sending on to device 24.!!!
fibaro3.JPG?psid=1
Temp not correct
to make 3in1 working good with Fibaro you must:
1) click 3in1 Master Device icon and go into advanced settings tab
2) add the following 2 variables:
Numer: 2
Data Type: 1d
Value: 1
Numer: 5
Data Type: 1d
Value: 0
save configuration and press the red button on the side of the 3in1 EZMotion
Best Regards
Guest lunakk
Numer: 2
Data Type: 1d
Value: 1
Numer: 5
Data Type: 1d
Value: 0
Can you send me description of those variables, a mean more info about advanced settings
Guest ericf
strange because on the doc of EZMOTION Wireless 3-in1 Sensor
you have the follwoing
Parameter Number Parameter Name Default
1 Sensitivity 200
2 On Time 20 Min
3 LED ON/OFF 255
4 Light Threshold 100
5 Stay Awake 0
6 On Value 255
Guest hotrot_net
Those settings work
Stil -13.8 degrees
Still detecting motion when theres no one in the room
DONT WORK
Sorry forgot a word
mmmm, strange, I've two 3in1 ezmotion and with these settings works pretty good.
in the current value column, do you have the right settings?
Guest hotrot_net
These are my current settings,
After a while the node goes dead.!!
Temp -13,9
No motion detection
Guest ericf
I have the same ...
Maybe delete all settings and resync it with your device to see if it solves the dead item.
Maybe the doc ofEZMOtion regarding the parameters are not align the way HC2 manage them. FIBARO should investigate in this.
Also I think for this type of box and interface, they should in the advance screen set all availbale/possible parameters by discovering the type of the device --> so if it discovers a EZMoton 3-1 then the advance screen should display all the parameters for this module ... this is a user-friendly-professional approach
Temp -13,9
No motion detection
I've got similar problem first time I configured it (I added all supported variables).
try to reset the device removing from the fibaro network and re-include. Then add "only" the two variables mentioned above.
let me know.
