V3.311 software, all comments HERE
Hi
new update 1.044 for upgrade V3
Liste des modifications de la version beta 3.311 Beta: WARNING!
Upgrade to Beta software cannot be reversed by standard software upgrade procedure. The only way to come back to official software is to use Recovery Mode, then use backup and upgrade to official software version. It is highly recommended to create backup file before attempting to install Beta software.
After update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
WARNING! After that update all scenes and users will be deleted. Admin password will be reset.
If this update lasts longer than 10 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
- New, faster system architecture.
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution,
- Added support for Lua scripts,
- Automatic conversion from graphic block scenes to Lua scripts,
- Added possibility for Lua debugging,
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Devices search engine at Your home page.
- New languages: estonian, latvian.
- Moreover 3000 minor bug fixes and improvements.
  • Answers 158
  • Created
  • Last Reply
Guest Fidziu
I have a big problem, all my Everspring ST814 temperature/humidity sensors aren't working anymore!!!
/emoticons/default_icon_evil.gif" alt=":evil:">
See:
Its battery operated device. It doesnt reconfigured during standard procedure becouse it was asleep.
Its not possible to reconfigure when battery operated device sleep.
Try to wake it up or add this device again.
Guest Futuretech
/emoticons/default_icon_evil.gif" alt=":evil:" />
See:
Like I said it is gonna be a long night!
Feedback/observations
My Horstman devices are not recognised correctly. They have a Danfoss image, and I've lost the ability to set parameters or associations on the thermostat, and lost the ability to switch the relay unit ON/OFF.
My DNS IP Address now reads "file" and I can't change it to an IP address
My Motion Sensor buttons are in Polish. Additionally, it's summarising power "0kwh" when in Rooms.
My IP Camera no longer displays images. Just has a small "No Entry" sign top left
None of my light switches are recognised as Vitrums
/emoticons/default_icon_sad.gif" alt=":-(" /> (EDIT: But they never did.. was just hoping)
Guest vayher
See:
Or try to use "Configure to default values" button in Advanced tab in device configuration and then wake it up.
Guest deraaij
Can you also upgrade from 2.141 or do I need to reverse first (I hope not...)
Mark
Guest MitchellOnline
See:
I removed one of the Everspring ST814 from the HC2, and re-added it. It just got worse:
Guest Futuretech
What means z-wave library (in config-panel) SIS and FLIRS
And what about the polling
Guest vayher
Maybe it's a conversion to new system error - can you try to reconfigure this camera or add it again?
Guest Fidziu
Futuretech,
To much to explain.
Check it:
in zwave 3.X chip you can not use both.
Guest vayher
See:
Did you try to wake up this device after re-adding?
Guest vayher
It should be removed from this version as it's not working yet. It will be activated in next updates.
Guest Fidziu
See:
This device is fully supported. But system has to configue it properly.
Try to wake it up and reconfigure.
Regardless of this we'r just checking this problem.
See:
I did push 3 times on the button on the Everspring ST814 to wake it up. The problem remains:
Guest Sander
Can I be add to beta test please?
I've deleted it and added it again. But no difference. No images. It's a Vivotek camera if that helps.
You haven't to be added.
Upgrade to 1.044 first...
Then wait a few minutes and keep looking in the "Configuration" tab. It should give you the option to update to the Beta after that.
Guest Sander
thanks! Now visible indeed! Updating now.
Is there someone who has also a Everspring ST814? I am wondering if there are more people with problems when using this Beta.
/emoticons/default_icon_exclaim.gif" alt=":!:" />
Guest GG
Hi!
I just got my Home Center (the day before yesterday).
So far, most things work well for me.
I have updated to 3.311 Beta, but now it is impossible to assign scens to rooms.
All scens are unassigned and if I try to assign a scen to a room, after saving, the scen reverts back to unassigned.
I'm just reporting this bug, so it can be fixed in the next release.
Thanks!
