V3.311 software, all comments HERE
Hi
new update 1.044 for upgrade V3
Liste des modifications de la version beta 3.311 Beta: WARNING!
Upgrade to Beta software cannot be reversed by standard software upgrade procedure. The only way to come back to official software is to use Recovery Mode, then use backup and upgrade to official software version. It is highly recommended to create backup file before attempting to install Beta software.
After update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
WARNING! After that update all scenes and users will be deleted. Admin password will be reset.
If this update lasts longer than 10 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
- New, faster system architecture.
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution,
- Added support for Lua scripts,
- Automatic conversion from graphic block scenes to Lua scripts,
- Added possibility for Lua debugging,
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Devices search engine at Your home page.
- New languages: estonian, latvian.
- Moreover 3000 minor bug fixes and improvements.
  • Answers 158
  • Created
  • Last Reply
Guest Fidziu
Hi!
I just got my Home Center (the day before yesterday).
So far, most things work well for me.
I have updated to 3.311 Beta, but now it is impossible to assign scens to rooms.
All scens are unassigned and if I try to assign a scen to a room, after saving, the scen reverts back to unassigned.
I'm just reporting this bug, so it can be fixed in the next release.
Thanks!
Thanx GG we will solve this issue soon.
Guest Futuretech
Well there are strange icons, wrong translations but no problems here.
Except the Everspring SP814-1 still not working.
Guest deraaij
Sorry for reposting but I am not dure if anyone saw my earlier post....
Is there also an upgrade Path to the new Beta from 2.1.41?
Guest Kuuno
are there any now supported devices in beta?
thanks
Hi!
Thanks!
See in beta release notes : "WARNING! After that update all scenes and users will be deleted."
I hope not in final release ?
Guest MitchellOnline
Hi!
Thanks!
It will also delete your custom icons
Guest GG
I've found another bug.
If I design a scen using blocks, and then convert it to Lua, the following block script does not convert properly to Lua. The problem are the timer blocks.
Guest vayher
Hi!
Thanks!
Are you sure that these scenes are being saved? In this system wrongly constructed scenes are not being saved (there will be a popup info about it in next releases). Can you see these scenes at main page?
Guest Adam
I have a big problem, all my Everspring ST814 temperature/humidity sensors aren't working anymore!!!
/emoticons/default_icon_evil.gif" alt=":evil:" />
See:
Its battery operated device. It doesnt reconfigured during standard procedure becouse it was asleep.
Its not possible to reconfigure when battery operated device sleep.
Try to wake it up or add this device again.
Or try to use "Configure to default values" button in Advanced tab in device configuration and then wake it up.
I removed one of the Everspring ST814 from the HC2, and re-added it. It just got worse:
This device is fully supported. But system has to configue it properly.
Try to wake it up and reconfigure.
Regardless of this we'r just checking this problem.
I did push 3 times on the button on the Everspring ST814 to wake it up. The problem remains:
Is the ST814 device is working properly after re-added?
Is the ST814 well displays temperature and humidity?
Of course NOT! We will release next beta version after proper feedback and then we will release STABLE VERSION (without all transcription inconveniences).
Guest vayher
About languages - in general - at login page you can change the language temporarily. To change the language permanently use flags in configuration section.
Guest GG
Hi!
Thanks!
Yes, I see all the scens at the main page, under Unassigned.
Guest vayher
No, we're working on scenes conversion from old version.
See:
I am staying to see this:
Now my heating system at my home isn't working anymore because the HC2 doesn't know the temperature by room anymore......
I have re-added the Everspring ST814 for a couple of times know, still the same problem...
When I push 3 times the wake-up button nothing happens.
Guest Kuuno
expresscontrols 3-1 sensor shows temp still in fahrenheit!
I was sure
/emoticons/default_icon_biggrin.gif" alt=":-D" /> . Thx Krystian
Guest vayher
Hi!
Thanks!
Hmm, strange. Does anybody else have this issue?
Discovered another bug:
When adding a custom icon, I get this:
Guest GG
I also have this issue; the event panel will not load properly.
When I click Event panel in Panels page, the web browser dims nothing happens.
After this I have to go back in browser to be able to do anything.
Guest vayher
System accepts only 128x128px icons. Are your icons that size?
