V3.311 software, all comments HERE
Hi
new update 1.044 for upgrade V3
Liste des modifications de la version beta 3.311 Beta: WARNING!
Upgrade to Beta software cannot be reversed by standard software upgrade procedure. The only way to come back to official software is to use Recovery Mode, then use backup and upgrade to official software version. It is highly recommended to create backup file before attempting to install Beta software.
After update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
WARNING! After that update all scenes and users will be deleted. Admin password will be reset.
If this update lasts longer than 10 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
- New, faster system architecture.
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution,
- Added support for Lua scripts,
- Automatic conversion from graphic block scenes to Lua scripts,
- Added possibility for Lua debugging,
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Devices search engine at Your home page.
- New languages: estonian, latvian.
- Moreover 3000 minor bug fixes and improvements.
  • Answers 158
  • Created
  • Last Reply
Is there already an update path know fir users currently on version 2.141 beta?
Guest Fidziu
Bas,
Guest deraaij
Thnx for the new beta! I see allot improvement since beta 2!
Is it correct that you cannot set Lili commands in the Beta?
I don't see that option anymore.
Mark
Guest Futuretech
Go into recovery mode and get back to first stable (1.038?) version and then update to 1.44 and then upgrade to 3.311
Guest vayher
HI
Since update V3.331, only the Power LED is on.
LAN and Internet are off.
In panel Paramter LAN, i can't change DNS Server , it's indicate" File".
There is another parameter "Techical ACCESS",=No, can't change it.
No remote access by HOME.FIBARO.COM
Is't a bug?
How can have again remote access?
Thants for reponse.
Remote access for this beta version will be released on monday/tuesday.
HC2 v3.311 is ready to work with remote access but we have to make some changes in home.fibaro.com.
Guest vayher
Mark
You can create Lili commands in Configuration->General by pressing "Reload Lili database" button.
Guest fab971
List bugs
- Impossible to go "Event Panel.
- translate "Modular alarm" in French
- translate "Satel control panel" in French
- "Aeon Labs DSB05 Z-Wave Multi Sensor 4-1" does not create multiple modules but change after a reboot for example.
The locations in Portugal are not working correctly with the yahoo database!
Is it possible to be added to the Beta?
If so how does one get added?
Just found out myself... Just updated to 1.0.44 and the beta popped up on the update page.
Initial noticable problems;
* Lan and internet LEDs not working
* Scenes are not running when programmed with the blocks. Just a simple scene turning off or on an Everspring AN157 does not run by either clicking run or by setting with the timer. Tried deleting them and re-creating but does not work. Manually turning on and off device works.
* When setting a scene with the blocks, there is something wrong with the interface. I can save one parameter or a time and go back in and it has changed. Tried using save button below window and the one on the sidebar. For instance, I set the timer to 'Exact time @ 22:00', save it and go back in and it has changed to 'At Sunset @ 22:40'.
* Cannot assign scenes to a room. When scene is assigned to a room and saved, go back in and it has changed back to unassigned.
* All the icons for the IOS app have reset to master bedroom icon.
Scotfree, turn on option "start with Hc2" in scenes
Thanks A.Socha. That worked. The scenes still do not run manually though like before. I can get around the other issue with the timer parameters not saving by deleting the timer block and re-creating it but there is definately something buggy about it.
When pressing Add for adding devices nothing happens. So I can't add devices. Is this a known bug? Or am I doing something wrong?
Bas, refresh site do you still don't see popup?
try turn on one device is works?
if yes try again add new devices
I tried multiple restarts and refreshes. There is no pop-up when pressing the add-button
Also can't access the history/event panel now - Brower locks up.
Guest domoticawireles
Here some bugs with fw 3.311
1) SF812 smoke detector does not figured as sensor, but as actuator. Device Kind "Unknown".
2) Casually loosing of connection for devices that worked well.
3) ST814 no longer working after some hours (before was working)
4) FGS221 V. 1.4 no configurations parameters
5) AN158 recognised as AN157. No energy / not working measurement.
6) Aeon Labs energy meter not working
7) ASR-ZW boiler actuator recognized as thermostat but is an actuator. HRT4ZW now working yet.
8) Armed / disarmed buttons not traduced in italian
9) In scenes, no Armed / disarmed condition is working
10) No longer possibility to set notifications for status changes of single device.
Guest Sander
I can confirm problems with the Horstmann HRT and ASR. I also have a problem with one of my TBKHOME plugs. I have several of these but with only one it wont turn of with the HC2. I can dimm it but dont turn it off. With the other 5 plugs this works fine. I tried reinclunde it but nothing.
*edit: Multiple plugs now have these problems!
New problem: When I try to change the image of a scene I get the message access denied.
New problem 2: Devices don't show in the iPhone app anymore.
Guest MitchellOnline
You have the same problem as me: The Everspring ST814 is no longer working after some hours.
Is it possible to temporarily go back to FW 1.043 and when there is a update for the Beta Firmware, return to the Beta?
