Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
FIBARO Home Center App 1.0.0 - release Read more... ×
FIBARO Home Center App 1.0.0 - wydanie Read more... ×
Guest deraaij
Sonos - Virtual Device
Guest deraaij
Update: Please use TCP as of version 3.x as os.execute has been depreciated. As soon as we are able to have custom headers I will update the LUA code.
Hi all,
For those who are interested I made a Virtual Device based on the new LUA feature (inspired on lua code for MIOS) which can control a sonos device. It uses curl but will change it when the http api is documented. Change the IP address accruing to your needs.
EDIT: Added additional comments from other post which I posted in this thread.
EDIT: Changed req.lua --> /tmp/req.lua which works with beta 3.423 & 3.424
Play
Stop
Pause
Previous
Next
Mute
UnMute
Volume – Not Working yet because we do not get the value off: _sliderValue_ @fibaro how does this work with Lua?
Example Text-2-Speech using LUA in a scene:
Remark: Play is initiated with the last statement to actual play the text (change it accordingly).
Example play song from network with LUA:
Remark: Play is initiated with the last statement to actual play the song (change it accordingly).
Example radio station via LUA:
Remark: Play is initiated with the last statement to actual play radio (change it accordingly). For now only the radio name is set.
Mark[/b]
Share this post
Link to post
Guest deraaij
  • With this code you can make scenes talk via son0s:
    Share this post
    Link to post
    Guest deraaij
  • Hi all,
    I have been playing around and found out that it also works when just using TCP commands. Also the volumeslider works. If you add commands be aware to change the content Length in line with the length of the body message.
    EDIT: Added way to get your own radio station.
    Play
    Stop
    Pause
    Previous
    Next
    Mute
    UnMute
    Volume
    Example Text-2-Speech using TCP:
    Remark: adjust lenght accoring to Soap body. And play needs to be initiated to actual play the text.
    Example play song from network with TCP:
    Remark: adjust lenght accoring to Soap body. And play needs to be initiated to actual play the song.
    Example radio station via TCP:
    Remark: adjust lenght accoring to Soap body. And play needs to be initiated to actual play radio.
    Ok, to get the correct url for your radio station do the following:
    1.) Play correct radio station on a zone.
    2.) Surf to http://<>:1400/status/radiolog
    3.) Take the correct url, and replace the one in the example code (
    Ungroup zone option 1
    Ungroup zone option 2
    This one proved to be a bit more stable for some users.
    Group to zone
    First check :1400/status/topology the UUID of your main zone, e.g: RINCON_000E58226B1601400
    Be aware that if you copy and paste the TCP variant it add's some spaces which you have to delete manually. After save of the radio variants html encoded text is changed to normal chars if you make a change and save it again it will not work.
    Mark
    Share this post
    Link to post
    Hi Mark,
    Can you give more information on how to use the TCP commands?
    In LUA i can control Sonos but have the same issue as you discribe earlier.
    After adding a virtual device with ip number x.x.x.x and TCP port 1400 and a button with one of the tcp commands doesn't give any result.
    Thanks a lot!
    Ruud
    Share this post
    Link to post
    Guest deraaij
  • I have been playing around and found out that it also works when just using TCP commands. Also the volumeslider works. If you add commands be aware to change the content Length in line with the length of the body message.
    Hi Mark,
    Thanks a lot!
    Ruud
    Hi Ruud,
    Be aware that if you copy & paste it adds some unwanted trailing spaces. If you remove those it will work
    Mark
    Share this post
    Link to post
    Guest deraaij
  • Thank you!
    You are welcome!
    This weekend I finished a python script which receives an update from the sonos as soon as something changes (Paused --> playing et cetera). I will post the info shortly.
    I use it to set my receiver to on and the correct input when someones hits play on the particular zone.
    Mark
    Share this post
    Link to post
    Guest deraaij
  • Hi I got some question on playing song and/or radio. So i want to share some more examples:
    In case of questions let me know.
    Mark
    Share this post
    Link to post
    Wonderful job deraaij!!!
    with the control and text2speech it's time for me to buy some Sonos 3 for my rooms.
    What about the sound quality? is really good?
    I was thinking to buy Bose, but now I think I wll buy the Sonos system.
    Regards
    Share this post
    Link to post
    Thank you so much! This is great!! + voice function! Absoluteley amazing!!!
    If you come up with more commands/functions please let us know
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/smile@2x.png 2x" width="20" height="20" />
    Share this post
    Link to post
    Guest deraaij
  • Wonderful job deraaij!!!
    Regards
    Your welcome!
    It depends on the size of the room which sonos is the best option. I have all the types and I am very happy with them. I would only not recommend the play:3 for a big room.
    Your welcome! I hope I have time to include art when playing a radio station.
    I also have a python script which can trigger a scene when a sonos starts playing. If some one is interested I will post it.
    Mark
    Share this post
    Link to post
    Very interesting !
    Can you advise on what is possible to do with V1.045 using http within a virtual device, please
    Thanks,
    YG
    www.ghafoor.org
    Share this post
    Link to post
    Guest deraaij
  • Hi,
    Very interesting !
    Thanks,
    YG
    www.ghafoor.org
    You can use the TCP versions. Those work both in the beta and the stable version. Lua is only available in the beta release.
    Mark
    Share this post
    Link to post
    Mark
    Thank you:), I am definately interested, but Im not that familiar with python scripting. Hope you can explain a little... Perhaps give a step by step guide or link to necessary documentation.
    Thanks again for your support.
    Share this post
    Link to post
    Guest deraaij
  • Hi am not a real programmer but it works. You need python and the twisted library:
    Obviously it will work in any other program language.
    Mark
    Share this post
    Link to post
    Thank you! Looks interesting!
    I was wondering if you have any solution to group all zones in house. In case of a fire alarm I want all zones to play a message on repeat. Now I have the solution for message and repeat (see below). But is there any command that I can group all zones??
    "Repeat all" command:
    POST /MediaRenderer/AVTransport/Control HTTP/1.1
    Content-Length: 308
    SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#SetPlayMode"
    0
    REPEAT_ALL
    0x0D0x0A0x0D0x0A
    Share this post
    Link to post
    Guest deraaij
  • Thank you! Looks interesting!
    Content-Length: 308
    0
    REPEAT_ALL
    0x0D0x0A0x0D0x0A
    Hi I had a look for you:
    First check :1400/status/topology the UUID of your main zone, e.g: RINCON_000E58226B1601400.
    Second step is to make sure no zone is grouped (per ip adress):
    Third step add members per IP Adress to one main zone (using the RINCON ID from step 1):
    Of course you could use LUA to loop through a list of IP adresses, but you have all the info to continue
    Mark
    Share this post
    Link to post
    Thanks, this is awesome!!
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/smile@2x.png 2x" width="20" height="20" /> Great job!
    Share this post
    Link to post
    Guest deraaij
  • Thanks, this is awesome!!
    You're welcome!
    Share this post
    Link to post
    Guest deraaij
  • You can also ungroup a zone by:
    Share this post
    Link to post
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
